exploded view of injector pump. - Ford Truck Enthusiasts Forums
Old 04-11-2007, 05:07 PM
f100guy f100guy is offline
f100guy is starting off with a positive reputation.
i am looking for an exploded view or diagram of an injector pump. i am going to take it apart and may need it to put it back together with the new parts. has anybody rebuilt one before.
Old 04-11-2007, 07:40 PM
KJLYPW's Avatar
KJLYPW KJLYPW is offline
KJLYPW is starting off with a positive reputation.
I am in the same position, I have a seal kit and will be installing soon, in my "old" spare pump. I have mine apart, take your time and make notes on how things are oreinted to each other, draw a bunch of diagrams. This seems to be super secret stuff, but really, if you dont have a test stand all you can do is change seals, and hope you dont change any adjustments too much. If you go to Diesel Care and Performance web site, under 6.9- 7.3 Ford, they have a parts breakdown available, and if you buy the seal kit they supply a specification spec sheet for a DB2-4541 pump- wha who! http://www.dieselcare.net/FORDPRODUCTS.html
On that note, if any one knows where a real, complete overhaul/repair manual may be available, I'd like to get one as well. Its not rocket science, its just a steel pile of parts that squishes fuel!!!!! HA HA-
Old 04-11-2007, 07:54 PM
there is a injection place close by that i am going to have them hone and replace the piston inside the pump and calibrate if needed. he said that most of the time, the piston inside the pump gets scared up and needs to be replaced.
Old 04-12-2007, 01:34 PM
caterpillar caterpillar is offline
caterpillar is starting off with a positive reputation.
word of caution i was told by a friend who is going to school for this stuff when you are working with the pump never let your bare hands touch anything internal, the oil on your hands can ruin the pump, always keep the parts in a bucket full of diesel fuel, just an fyi if anyone didn't know
Old 04-12-2007, 09:25 PM
PLC7.3 PLC7.3 is offline
PLC7.3 is gaining momentum as a positive member of FTE.
Quote:
the piston inside the pump gets scared up and needs to be replaced.<!-- KEN: 1-13-2007: show 300x250 ad-block to non-Club FTE users in the 1st post of every page --><!-- / Ken, end of hack --><!-- / message --><!-- no sigs except when logged in --><!-- sig -->__________________
That is correct BUT there are only so many times they can be honed and re pistoned.......
1992 F150 / Body diagrams Lefty64 Missouri Chapter 1 03-21-2008 08:23 AM
? 351w exploded view jimbob21rc Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 01-30-2008 12:42 PM
Exploded view transmission Mollie 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 0 05-19-2004 10:46 AM
C6 valve body exploded view???? skinsey Clutch, Transmission, Differential, Axle & Transfer Case 0 03-02-2004 09:17 AM
...exploded view of a '71, 360 engine Mike W 1967 - 1972 F-100 & Larger F-Series Trucks 4 09-29-2002 07:18 PM
Tags
1987, 69, 73, 73l, air, diesel, engine, exploded, f250, ford, idi, injector, installing, pump, view
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
