Tie Rod Ends change interval?
Old 04-11-2007, 12:36 PM
cordespc's Avatar
cordespc
cordespc is offline
Hey folks,
I have a 99 F150 4x4 with 150K. I recently replaced the lower ball joints and control arms which cured all of my knocks and rattles. I'm not sure if I should replace the tie rod ends before having it aligned. Any advice on this one? Thanks,
Paul
Old 04-11-2007, 01:04 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is online now
I would throw new tie rod ends in as long as you are having the truck aligned, especially with the high mileage of your vehicle. They are fairly cheap and easy to do. I would hate to see you have a tie rod die in another 10k and then have to pay for yet another alignment.
Old 04-11-2007, 07:31 PM
cordespc's Avatar
cordespc
cordespc is offline
Thanks for the advice. I went ahead and changed them tonight. Guess I'll get the truck aligned in the next few days.
Old 04-12-2007, 01:32 PM
jimm66's Avatar
jimm66
jimm66 is offline
Did you do all? What did they cost?
Old 04-12-2007, 02:59 PM
MisterCMK's Avatar
MisterCMK
I have a nice link for doing your own alignment.
It is on a Mustang, but the principles are the same for your truck.
http://bio.fsu.edu/%7Eheath/mustang/alignment/
I aligned my Explorer with this method. When I took it in to have it checked, the alignment shop didn't need to do anything to it.
Old 04-12-2007, 09:05 PM
cordespc's Avatar
cordespc
cordespc is offline
Ummm...$45 EA for control arms (x 2) and $28 EA for tie rod ends (x 4). Ten percent military discount at Advance auto. No great difficulty, a cake walk compared to the lower ball joints. Recommend a 4lb hammer and pickle fork if you run into some resistance. Good times
Paul
Old 04-12-2007, 10:20 PM
jimm66's Avatar
jimm66
jimm66 is offline
I would have my friend do it , he's a mechanic. I might help.
Old 04-28-2007, 09:17 PM
Hartwa's Avatar
Hartwa
Hartwa is offline
Can anyone tell me what the total toe in should be on an 02 F150? I used the method that misterCMK recommended. Should I see a difference of 1/8" on each front wheel for a toral of 1/4"?
Kalahari south afric
06-22-2015 09:03 PM
CWPLUNGIS
05-09-2015 02:35 PM
f150crewcab
07-08-2014 07:49 PM
BabyG555
2004 - 2008 F150
01-04-2014 11:06 PM
paul7sola
New Member Introductions
12-27-2013 10:23 AM
Quick Reply: Tie Rod Ends change interval?
