Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Canadian National Chapter > Ontario Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ontario Chapter Join Chapter>, Leader: loudfords
  #1 (permalink)
Old 04-10-2007, 11:33 PM
Stoogefan Stoogefan is offline
Garage is empty, add now
Stoogefan is starting off with a positive reputation.
Part question
Howdy all .... quick question. While tinkering with my truck over the weekend, I noticed a part that needs to be replaced (it rotted thru) .... only I don't have a clue what it is. It's on my `85 F150 carb'd 351W ... it's a steel tube that runs between the engine and the firewall, which bolts to the backside of each head. Any ideas as to a name for this part ? I don't want to look like a complete idiot when I go to get a new one and have to draw a picture ... hehe
Thanks guys ...
Jeff
  #2 (permalink)
Old 04-11-2007, 12:38 AM
taisa899's Avatar
taisa899 taisa899 is offline
taisa899 is gaining momentum as a positive member of FTE.taisa899 is gaining momentum as a positive member of FTE.
I know exactly what part you are talking about but I can't remember the name of it for the life of me. It's up to you if yoiu want to replace it but I didn't. on my truck I just cut 2 pieces of sheetmetal and drilled a hole through it that a bolt could go through and bolted them in place covering up the hole for the tubes
jim
__________________
anybody wanna race???
  #3 (permalink)
Old 04-11-2007, 08:05 AM
DIRTY289 DIRTY289 is offline
DIRTY289 is starting off with a positive reputation.
I used to have a 1986 F150 with a F.I. 302.
On that truck those tubes actually went into a small block that was bolted onto the back of the head. I unbolted those blocks and found that the holes in the head for the tubes were threaded from the factory. I found a bolt to fit and that sealed the hole with no problems.
It was a pain to work on because of the location.
  #4 (permalink)
Old 04-11-2007, 08:12 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Thermactor tube from head to head, usually a dealer only item, most have the check valve threaded on. The check valve (9A487) comes separate, and can be a b!tch to remove. You'll need two gaskets also.
Two different tubes~production date change~look on VIN or certification label for build date.
1-D9AZ-9B449-A .. Exhaust Air Supply Tube~Use before 9/84
OR
1-E5TZ-9B449-C .. Exhaust Air Supply Tube~Use after 9/84
2-D7DZ-9C435-D .. Exhaust Air Supply Tube Gaskets~Same for either tube.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #5 (permalink)
Old 04-11-2007, 11:12 AM
loudfords's Avatar
loudfords loudfords is offline
1979 Ford F-150
loudfords has a good reputation on FTE.loudfords has a good reputation on FTE.
Why not try a used one? I might have one from an 88 351 kicking around somewhere...
__________________
Chad - loudfords - Ontario Chapter Leader
Click HERE to join the Ontario Chapter
1979 F150 351W
2003 Explorer XLT
Tags
75, 9b449, az9b449a, bolts, crossover, d9az9b449a, e5tz9b449c, ford, number, part, pipe
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
