Cam & Mass Air Sensor?
#31
Originally Posted by Chas.
It's the 2-tube intake job with the 2 venturi's in front of the sensor. CK
But, to my knowledge, the only thing that piece does is allow air from both hoses to be able to enter the "Idle Air Control" or IAC. This neat little gizmo adjusts, at 0% throttle, to let just the right/small amount of air into the intake manifold to keep your truck at a smooth idle. It completely by passes the throttle body.
I cut the restrictor horn thingys off and I can honestly say that I felt the difference. My thought process-->Is it easier to breath through your mouth or nose? So why wouldnt be easier for your truck to breath with less restriction?
#32
Go with a complete header to tailpipe system. Gale Banks Engineering Stainless headers are awesome. I, too, was looking for power, big hills slowed me down, when loaded etc. above 2500 under full load, full throttle, it was a pooch. The simple addition of a complete, engineered, well built system, made a new truck out of it. I'm happy. I've a 250 with 410 gears.
#33
#34
Can anyone confirm or deny the 1994 F350 W/7.5L 460 having a stock Mass Air Flow sensor (MAF)? I can't find one on my truck. Although I bought it with a K&N air filter, I don't know if the air box was changed or not. I'm leaning towards no, just the drop in filter. A picture of a stock air box setup would also be helpful.
Any info is GREATLY appreciated!
Jeff
Jeff
#35
#36
Jeff
Jeff
BrettMavriK
100
01-14-2018 11:08 AM
bnalley91
11-12-2015 09:04 AM
dan15000
01-29-2014 08:20 AM
BigBlockF-250
10-05-2004 09:59 AM
