Electric Heat In '08?
Living in Seattle area this is something I really enjoy on my 08. After sitting all day I start the truck and there is immediate warm air coming out. Cab is warmed up in no time as if the engine were already at normal operating temperature. I believe it uses technology similar to an electrical space heater I would assume. Can smell the coils warming up for about 2 seconds whenever it's used. It's definetely worth the money though for those of you that are living in a cooler climate!
Originally Posted by bneafus
That was my thought! Does it have an automatic thermostat, or just manual on and off? It'd be awesome here in Denver!
It works very well. It is similar to a toaster element. There is an electric current that runs through a resistnace to heat up the element. It is contained in the heater box in the same proximety as the heater core. I belive that it is actually interfaced with the climate controll. It will heat my crew cab up in 3-4 minunites.
how warm is the air that comes out the vent with urs. I have the same thing and there is no way its warming up the truck in 3-4 minutes. (Maybe mine has an issue)
The air to me coming out of the vent by feel isnt really any warmer.
I don't know how warm the air is temp whise. It is very close to the same temp as the air coming out when the truck is up to temp but the volume of air coming out is not as much. My cab is warm before my watrer temp gauge even thinks about moving, so i don't think that I am even going to bother with remote start.
I am not sure temp wise. It is close if not the same temp as when the truck is up to running temp. The only thing that I noticed is that the volume of air coming out is not as much as when the water is up to temp and the heat is coming from the heater core and not the element. My guess is that it is because to much air across the element would cool the element off to quickly and the air would become cold, but I don't know I didn't design it.
