Whining Power Steering Fix!!! - Ford Truck Enthusiasts Forums
Old 04-10-2007, 09:55 AM
sne97hd sne97hd is offline
sne97hd is starting off with a positive reputation.
I finally fixed the noisy piece of junk power steering pump in my 97 F250 HD 7.5L. The pump I used is the infamous saginaw conversion from any parts house, part# 20-6244. If you haven't heard of this pump before it is made by A1 Cardone to fix the noisy ford pumps and you can get it at any parts supplier that carries A1 Cardone parts. I got mine at Advance Auto Parts for $65. I used a new pressure hose from a '79 F250 and it was a simple bolt in replacement. This conversion does work and the pumps do exist!!!! Everyone should do this swap if you hate your noisy pump!!!!! It's EASY!!!!
Old 04-10-2007, 10:20 AM
gustang818 gustang818 is offline
gustang818 is starting off with a positive reputation.
Very nice! Some of the guys here have done it with Ford junkyard parts:
http://www.ford-trucks.com/forums/59...+steering+pump
Old 04-10-2007, 11:22 AM
unixadm unixadm is offline
unixadm is starting off with a positive reputation.
Alright you've got my attention. Assuming I can locate that pump, did you need anything else to perform the swap? I have a 1996 F250 HD 7.5L, so whatever worked for you should work for me. I just want to get it right the first time as my power steering sounds like CRAP. I work for an AutoZone company and bought a remanned PS pump already, but I can return it as I have not installed it. AutoZone carries Cardone, but when I looked up the part number in our new parts system, it was listed as not available. Partsamerica.com does carry it online for $85 plus the core.
Old 04-10-2007, 01:09 PM
All I used was the pump and a new pressure hose that fits a 1979 F250. I don't remember the part # and I threw the box away. The new hose DOESN'T look or fit EXACTLY like the original one but it is very close and it works. You may try searching for part# 206244 (without the dash) at Autozone. The swap only took me a couple of hours, it's EASY!!! You mentioned Partsamerica.com, I got mine at Advance Auto Parts, which is owned by partsamerica. I ordered it from the store, not online, and it arrived the next morning. They even took my old pump as a core, so I payed $65 for the new pump!
Old 04-10-2007, 02:03 PM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
There is no Advance Auto within 500 miles of where I live, but Napa has the part. They ordered it for me. I'll take some pictures during the install and make it into a tech article.
Old 04-10-2007, 03:04 PM
Bruce R Leech Bruce R Leech is offline
Bruce R Leech is starting off with a positive reputation.
I just keep mine serviced and it stays quiet. but if I ever have one go out I will consider that pump. but these thing seem to last forever with a occasional flush and oil change.
Old 04-11-2007, 08:40 AM
fmr9 fmr9 is offline
fmr9 is gaining momentum as a positive member of FTE.
Andym are you doing this on your 89 with the 300?
If so, I'm anxiously awaiting your report. My 90 with the 300 sounds OH SO LOUD!!!
I have had people in parking lots stop and stare while cranking the steering around to get in or out of a spot.
Frank
Old 04-11-2007, 09:07 AM
EgoMan EgoMan is offline
EgoMan is starting off with a positive reputation.
Looks the same as mine, think it would fit my f-150....same thing.
Old 04-11-2007, 12:06 PM
andym's Avatar
fmr9, nope, this is going in the Bronco. The 89 is going up for sale as soon as I get around to replacing the transmission.
Old 04-11-2007, 01:22 PM
ErnieX ErnieX is offline
ErnieX is starting off with a positive reputation.
Did the Saginaw pumps come as OEM on any models? May want to look for one at the junk yard.
EE
Old 04-11-2007, 05:21 PM
As far as I know the only Ford trucks with Saginaw pumps from the factory were some of the fullsize vans. I don't know year models though.
Old 04-11-2007, 06:51 PM
lostin90s lostin90s is offline
lostin90s is starting off with a positive reputation.
Alot of years vans had them according to a parts search I've done . Most recent conversions have been from 92-95 vans . Last one was 95 E150 van with 351 ,the guy bolted it right up to a 302 . But if you find one with 460 etc. Should be fine . You will need the mount ,pump and pressure hose form van .
I drain and refill pump every year and at around 125000 every one has got noisy. The Saginaw doesn't and likes big tires to.
Old 04-11-2007, 08:14 PM
Redcat Diesel's Avatar
Redcat Diesel Redcat Diesel is offline
Redcat Diesel is gaining momentum as a positive member of FTE.Redcat Diesel is gaining momentum as a positive member of FTE.
Quote:
My 89 E250 with a 300 has the Saginaw pump if that helps.It's just a base model work van.
Old 04-15-2007, 08:56 PM
BigJim191's Avatar
BigJim191 BigJim191 is offline
BigJim191 is starting off with a positive reputation.
Yup my PSP is whining very loud too. I thought maybe it was low on fluid but that wasn't the case...i'm glad i found this thread now i know i'm not the only one with this problem...i'll be going to NAPA for this one...
Thanks
Old 04-16-2007, 12:02 AM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
Typical ford problem.
Mine has been replaced, and leaks and whines still. I have the recipt from the previous owner.
Noisy Power Steering yabadaba 1967 - 1972 F-100 & Larger F-Series Trucks 10 03-15-2017 05:17 AM
Noisy Power Steering 66F250CS 1961 - 1966 F-100 & Larger F-Series Trucks 16 05-02-2015 11:33 PM
Saginaw P/S Upgrade--Hose build? F-250 restorer 1973 - 1979 F-100 & Larger F-Series Trucks 2 12-13-2014 03:33 PM
1989 F150 4.9 300 4x4 Power Steering Pump? piersol 1987 - 1996 F150 & Larger F-Series Trucks 24 01-26-2010 11:09 AM
Hydroboost and Power steering pump aldridgec 1999 to 2016 Super Duty 2 02-01-2009 08:28 AM
Tags
206244, 94, autozone, cobra, f150, ford, noise, number, part, power, pump, steering, whining, wine, wining
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
