Whining Power Steering Fix!!!
#196
I doubt it will, but if you look at the billet Saginaw bracket it should hold the Ford E series version easily.
Post 184, farther up this very page.
You posted in 2007.
Yes, Corporate, Second generation.
Interested to hear the results.
Maybe that's why the pump I bought was on sale for $40.99?
Cardone calls it "magnapure filtration' but every Saginaw I've ever seen has a magnet inside.
You posted in 2007.
#197
Beat a dead horse
I am new to this forum. Hi everyone. I dont want to add to the drama but is the cardone 20-7878f the same as the original replacement the cardone 20-6244? Thanks. By the way i am wanting to put this on a 79 ford f150 with a 302. Is this the best or right option? Or should i go with a pull a part van saginaw? Thanks again
#198
#200
#201
#205
The Saginaw is silent in operation and won't spit up if you turn the wheel while the engine is off.
It seems to have more power. (subjective on my part)
The wheels don't shudder when turning at a stop, and it does not scream when against the locks.
Many of the rockcrawler guys would blow a C2 pump the first day of use.
Just go read FullSizedBronco or BC Bronco's forums.
Basically, Ford didn't want to pay GM for millions of power steering pumps any more.
Saginaw was (is?) a division of General Motors.
#206
Probably doesn't have the pressure the van pump does.
... and the return line would be pointing at the steering box.
Be mindful that buying a pump outright will not get you a cap.
So you better pick one of those up too.
#207
The internals are very different!
#208
So the 20-7878f would have all the pressure i need just like the 20-6244 that are no longer available? All i have to do is figure out what bracket to use to mount it. Or build my own. Correct?
#209
#210
Midsized car application. (Granada, Monarch, etc...)
