Whining Power Steering Fix!!!
Old 03-25-2011, 01:38 PM
jk89cat's Avatar
jk89cat
jk89cat is offline
no it wont, it is a different style pump
  #137
Old 03-25-2011, 02:04 PM
Harabec's Avatar
Harabec
Harabec is offline
Yeah, hence that horseshoe bracket right? It was my understanding that the pump itself won't fit any of the F150s or econolines, so they are fitted with a bracket to line it up
  #138
Old 03-25-2011, 03:03 PM
jk89cat's Avatar
jk89cat
jk89cat is offline
the late 80's and early 90's e- vans used a saginaw pump that actually looks almost identical to the gm style. ill try to take a picture of mine tonight. the bracket is different between the f series and e vans for this reason.
  #139
Old 03-25-2011, 03:17 PM
Harabec's Avatar
Harabec
Harabec is offline
So I'd have to find a Saginaw pump off an f-series if I want it to come with the bracket that'll fit my truck is what you're saying?
  #140
Old 03-26-2011, 05:29 AM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
The black horseshoe adapter is to adapt and fit the Saginaw to the diecast later style bracket.
Cardone made them up this way but there is too little demand now.
Napa still lists the NSP 816795 online but I've been told by others on the forum they can't get it even though it's shown as available.
None of the factory installed Saginaws came with a horseshoe adapter.
The Saginaw came in two styles.
The oval reservoir that 86F150302 shows, and the "canned ham" style with a triangular metal body.
Why can't you just use the stamped steel bracket from a van with the same engine you have?
Originally Posted by Harabec
I just got off the phone with a shop that listed having a Saginaw pump off a 95 econoline with the same motor as me. They too said that the bracket it was attached to was a sheet metal piece to one side with two bolts similar to the one I found in the van at the pick and pull. Shouldn't these have the black horseshoe shaped bracket to fit the 3-bolt pattern in my truck? I'm very confused..
  #141
Old 03-26-2011, 05:40 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I just went to NAPA Online and searched the above number.
Select 'shop online' and then say 'no' to specific vehicle popup prompt windows.
It comes up at $92.49 w/ a $50 core.
You can see 4 views of the pump with standoff bracket.
It has the correct hose adapter already attached to the rear.
Store Locator | NAPA Online
  #142
Old 03-26-2011, 07:18 AM
Scndsin's Avatar
Scndsin
Scndsin is online now
Originally Posted by ArdWrknTrk
...None of the factory installed Saginaws came with a horseshoe adapter.
Didin't know this. Does this mean that those of us with the cardone units can bolt the horseshoe on a regular GM pump if & when it craps out? I wonder about the shaft diameter as well.
  #143
Old 03-26-2011, 07:23 AM
jk89cat's Avatar
jk89cat
jk89cat is offline
i didnt get a chance to last night , but when i am out messing with the truck ill snap a picture of mine
  #144
Old 03-26-2011, 07:34 AM
Harabec's Avatar
Harabec
Harabec is offline
I only had found a single e-van with my motor, and glancing at the pump it looked as if it was mounted in a totally different fashion than my pump mounts. I'll try to get over to a pick-n-pull today and if its not raining too hard i'll snap some shots to try to illustrate what I mean.
I wonder if I try to order one from napa if they'll be able to fish one out of the warehouse somewhere.. seems like it's worth a shot.
  #145
Old 03-26-2011, 08:18 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I don't doubt that it mounts differently, look at the lack of space in the van's engine bay.
If anything I'd expect there's more than enough room in the truck to use the van style bracket.
If it changes the belt length you'd need would it really matter that much as long as the pulleys are in the same plane?
  #146
Old 03-26-2011, 08:55 AM
Harabec's Avatar
Harabec
Harabec is offline
I'll see if I can pull one from a van today and get a way for it to fit. I'm not sure if there is a way to get it to mount and keep the pulley in plane with everything else.
  #147
Old 03-26-2011, 09:34 AM
jk89cat's Avatar
jk89cat
jk89cat is offline
my saginaw pump pictures, i am using a 95 e-van pump and bracket and the e-van ps prssure line, i had to slightly extend the return line to the back of the pump.
  #148
Old 03-26-2011, 10:37 AM
fastpakr's Avatar
fastpakr
fastpakr is offline
What belt are you using with the E-van bracket and pump?
  #149
Old 03-26-2011, 11:26 AM
jk89cat's Avatar
jk89cat
jk89cat is offline
just the stock 5.8 belt
  #150
Old 03-26-2011, 04:05 PM
fastpakr's Avatar
fastpakr
fastpakr is offline
Excellent. Last question (probably) - how did you 'extend' the return line?
Edit... Nevermind, didn't realize it was just a hose connection rather than a fitting like the pressure hose. Now I just need to chase down a bracket.
Quick Reply: Whining Power Steering Fix!!!
