spacers = paperweights... nothing more... pm me for my address and i'll send you a small piece of aluminum for less than the cost of the spacer - it'll be better for the both of us
Those spacers are a joke,and as it's already been said- are worth nothing. A larger throttle body only makes it "feel" like you're gaining power. In reality,all you're doing is allowing more airflow to happen at partial throttle than the OE throttle body does. Max airflow will not change-a 70mm throttle body is sufficient to supply air to a very aggressive engione with alot of camshaft and headwork,along with a much better intake manifold.So believe me-you're going to gain nothing by changing the OEM throttle body on your truck engine to a larger one.
JL
