pics of lowered 67-72 ford trucks?
Old 11-27-2007, 10:11 AM
Marz-68's Avatar
Marz-68
Marz-68 is offline
Here are a few more.Name:  103_0671.jpg
  #77
Old 12-02-2007, 08:41 PM
wagontrainer's Avatar
wagontrainer
wagontrainer is offline
Lowering a 1971
What's the easiest way to lower(1"-2") a 1971 F100 with out spending too much and not chopping or cutting up the truck?
  #78
Old 12-02-2007, 09:11 PM
convincor's Avatar
convincor
convincor is offline
front, cut the coils.
rear, shackle kit-
http://www.djmsuspension.com/Product...5F100Parts.htm
  #79
Old 12-02-2007, 09:12 PM
convincor's Avatar
convincor
oop's double post
  #80
Old 12-02-2007, 09:28 PM
wagontrainer
[QUOTE=convincor]front, cut the coils.
rear, shackle kit-
http://www.djmsuspension.com/Products/ProductsByMake/Ford/65F100Parts.htm[/
QUOTE]
That was fast.Thanks for the info.
  #81
Old 12-02-2007, 09:52 PM
ceetwarrior's Avatar
ceetwarrior
ceetwarrior is offline
damn that thing is DUBBIN! Get some primer on that bad boy for the love of GOD. =)
  #82
Old 12-02-2007, 09:56 PM
EppersonRacin's Avatar
EppersonRacin
EppersonRacin is offline
trucks simply badass.
  #83
Old 12-02-2007, 10:11 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
"Beemer Nut" is offline
You want a sticky mess try dropping a F250 4" in the front and 6" in the rear plus still maintain front camber and load carrying capacity in the rear with leaf springs no airbags.
I was thinking (danger here) why not use the taller spring towers off later trucks (1972) on a short spring tower truck (1967-67) then cut the forged "I" beam end for a little longer drop on a donor beam and add this to your existing beam for more of a drop plus a correction of the camber? "V" notch to a pencil point at this joint then Tig weld it fully until it looked stock then have it retempered to stock beam specs? In the rear invert the spring pad mounts below the axle and reweld with the correct pinion angle, shorten the driveshaft as needed. Shave down the bump stops for maximum suspension travel, this way you will have a lowered truck that can still carry a load and still daily drive it. This a mild lowering not a slammed truck with air bags I must add. Ideas without spending money on those high dollar kits that some must have.
  #84
Old 12-10-2007, 10:02 PM
jamescanon's Avatar
jamescanon
jamescanon is offline
sweet ride tgowers ... I have a 67 f250 i have looked for a lowering kit but I have had no luck . where would one find a lowering kit ... and again YOUR TRUCK ROCKS
  #85
Old 12-12-2007, 03:48 PM
jsutton's Avatar
jsutton
jsutton is offline
  #86
Old 12-12-2007, 08:46 PM
jamescanon's Avatar
jamescanon
Thanks Awsome !!!!!!!!!!!!!!!!!!!!!!!!!!!!
  #87
Old 12-26-2007, 09:46 AM
meanirishmofo's Avatar
meanirishmofo
meanirishmofo is offline
That link says it's for a F-100 and I don't see one for the F-250, Are they the same?
  #88
Old 12-26-2007, 10:12 AM
jsutton's Avatar
jsutton
jsutton is offline
I think so but I'm not 100%. There is a user on here, FORD141 he has an F250 and put the F100 beams and stuff on it. He also converted to the 1/2 ton spindles too. I don't know if you have to do that, but you could try to check with him and see.
http://airbagit.com/product_info.php...oducts_id=5304 these from AIM are listed for F100,F150,F250. hope that helps
IBE-FO6579 $489.00
1965 - 1979
Make: FORD
Model: F100,F150,F250LD
  #89
Old 12-27-2007, 12:52 AM
MWaitt's Avatar
MWaitt
MWaitt is offline
Originally Posted by tgowers
this is my 68 f100. no air bags...that is the everyday ride hieght. my gallery is full of pictures. i hope this helps.[/img]
That is one sweet ride. I have a stock 1966 Ford that I would like to lower as well. What exactly did you do to get your awesome truck, to that ride height? And what size tires are you running?
  #90
Old 12-27-2007, 01:09 AM
Dave Severson's Avatar
Dave Severson
Dave Severson is offline
My '71 began it's life as an F-250, converted it all to F-100 suspension front and rear from a donor '73. Takes a bit of work to get things to fit, only difficult part was getting the right combination of springs and hangers on the rear. Pics in my gallery if you're interested.
Quick Reply: pics of lowered 67-72 ford trucks?
