pics of lowered 67-72 ford trucks? - Page 12 - Ford Truck Enthusiasts Forums
  #166
Old 08-22-2010, 06:16 PM
Quick69 Quick69 is offline
Quick69 is starting off with a positive reputation.
new wheels are on along with some 255/70 bfg's
  #167
Old 08-22-2010, 06:20 PM
Phil105's Avatar
Phil105 Phil105 is offline
Phil105 is gaining momentum as a positive member of FTE.
VERY NICE LOOKING TRUCK - hope you're staying close to original.
Phil
  #168
Old 10-08-2010, 04:39 PM
tcscustoms tcscustoms is offline
tcscustoms is starting off with a positive reputation.
Tony, Love the truck. I have been searching for some ideas for a 68 that Im about to buy and you just totally put me in the zone. Cant wait to get mine to the hight of yours. I will be runnin without bags for a while to. But, I still want the stance that your truck has, even if I never get bags at all. Is the ride still smooth at that level?
  #169
Old 10-08-2010, 06:17 PM
choochoof150's Avatar
choochoof150 choochoof150 is offline
choochoof150 is starting off with a positive reputation.
My rims are 20x9 front and back. Tires are General exclaim uhp's 235/30 front and 265/50 out back.
  #170
Old 10-09-2010, 12:31 AM
carpenter547 carpenter547 is offline
carpenter547 is starting off with a positive reputation.
Quote:
Originally Posted by MychalCrowson View Post
"Photo Sharing and Video Hosting at Photobucket">
oh man brb gotta change my shorts.
  #171
Old 10-09-2010, 01:20 PM
lucky_strike's Avatar
lucky_strike lucky_strike is offline
lucky_strike is starting off with a positive reputation.
is it hard lowering the trucks with the twin I beam, id really like to lower mine but so far the shops that ive called said they done do it.
  #172
Old 10-09-2010, 01:22 PM
depends
lowering difficulty depends on your desired drop and your budget.
  #173
Old 10-14-2010, 10:16 PM
westco westco is offline
westco is starting off with a positive reputation.
Quote:
Originally Posted by Quick69 View Post
just lowered mine last weekend
1/2 flip on rear
1 1/2 coil cut on front
looks good...what does 1/2 flip on rear mean?
  #174
Old 11-03-2010, 03:42 PM
it means you flip the front hangers of the leaf springs upside down
  #175
Old 11-03-2010, 03:45 PM
  #176
Old 11-03-2010, 08:43 PM
cavinandpavin cavinandpavin is offline
cavinandpavin is starting off with a positive reputation.
Quote:
Originally Posted by tgowers View Post
if you want to go as low as mine you can't do it with beams.... my buddy and i used a 1971 lincoln front frame section from the firewall forward. the rear is c-notched. the lincoln front suspension is all stock... the control arms are stock, the shocks are stock, the disc brakes are stock, the sway bar is stock... the only thing that is not stock are the front springs... my buddy had an extra set of g-body buick springs that were the exact same size as the stock lincoln springs, so we put them in...they were free. good luck. look at my gallery and you can see a bunch of pictures.
tgowers, your truck sits perfectly. i have been on the fence on how to lower my 65. so i joined this site just to ask you a few questions if you dont mind. first, what model lincolin did you use? it looked as though it was the same width right? was the bolt pattern the same for the wheels or di you drill out the disks? thanks and again good job on the truck!
  #177
Old 11-24-2010, 08:59 AM
tgowers's Avatar
tgowers tgowers is offline
tgowers is starting off with a positive reputation.
71 lincoln continental. it worked out to be the perfect width. the bolt pattern is different, so i just ran the stock lincoln wheels up front. There was a ton of fab work, but you can look through my pictures and see a lot. the steering box from the lincoln won't work, i used a rack from a taurus. had to notch the front crossmember to allow the oil pan to clear. had to use a summit oil filter relocater to mount the oil filter to the core support. used the stock licoln disc brakes up front with the stock truck drums out back. wildwood proportioning valve to dial doan the rear brakes to allow full pressure to the discs.... and a residual valve in the rear line to keep the drums from draining off. fab new motor mounts. have a look at the picks, and then let me know any other questions.
-Tony
  #178
Old 11-26-2010, 08:17 PM
crewcabfan's Avatar
crewcabfan crewcabfan is offline
crewcabfan is starting off with a positive reputation.
here is some of my own.
this one i owned for a year, never really had a chance to drive it. too many mechanical issues.
this one my pride and joy.
  #179
Old 11-27-2010, 12:07 AM
that crew cab is AMAZING!!
  #180
Old 02-11-2011, 02:12 PM
1971 f100 1971 f100 is offline
1971 f100 is starting off with a positive reputation.
1971 F100 Lowered with beams in front rear hangers and shackles. 390 C-6 all original paint. More plans for theengine and suspension. I think I'll leave the paint because of the pantina'd look.
horn style vidaliaman 1967 - 1972 F-100 & Larger F-Series Trucks 5 01-27-2016 02:09 PM
NOS 67-72 ford truck doors yes NOS! bigwin56f100 1967 - 1972 F-100 & Larger F-Series Trucks 13 03-03-2015 12:20 AM
Hood for sale '67-72 dclowrider Ford Truck Parts for Sale 0 07-23-2014 04:16 PM
WTB: 67-72 f100 inner fender PAR34 WTB - Parts & other 2 06-11-2014 08:23 PM
WANTED: 67-72 F Series radio delete plate 67M250Highboy WTB - Parts & other 3 04-15-2013 08:34 AM
Tags
67, 6772, 72, 72ford, bagged, bags, f100, ford, lowered, patina, rat, rod, shop, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
