87-96 Front Cross member
Hey all I'm wondering if you guys can help me out.. I have an 87 Bronco, but should be the same from the front seats forward as an F150. Well the front cross member where the passanger side I-beam bolts to is broken. Got a nasty crack almost 1/2 way through the cross member..
Is it part of the frame, i.e. welded, or can it be unbolted? I crawled under there and I think it's not removeable.. Trying to get other input on it.
If you're wondering how it broke, a TTB suspension with 40" boggers works wonders.
I don't want to weld it because it might just break it again.. Though I could reinforce it with some think plate and bolts, but I doubt I could ever get it to allign correctly.
I'm thinking of just buying a 87-96 F150 and moving all my lift, tires, motor,tranny over to it.. I've got to much into it to just give up..
Thanx for the input all..
Oh in case anyone is interested here is the specs on our BKO
87 frame and tub
90 doors, hood, fenders.
96 351w motor
79 C6 tranny w/ shift kit
8" Skyjacker SL with extended radius arms
3" BL
40" Super Swamper Boggers.
Stock gears.. (yea yea it sucks) but I have a 9" in the back and some 5:13's waiting to go into it. Then I just need to put the 5:13's in the front
87 frame and tub
96 351w motor
3" BL
Yea I know a solid axle is the way to go.. Alas I'm about at the height limit that California allows.. We've already been pulled over and ticketed a couple times for it but have fought them both and won.. I'm not sure if I want it higher..
It was cracked when we bought it.. The PO dumped it into a ditch.. Hard enough where it broke the radius arm.. I had it welded up, but it re-broke again...
We mainly have it for mud bogs.. So actually the ttb will handle the 40's. It's not a big rock crawler...
