Doug Herbert cams and lifters
also if your going solid roller, usually the lifts are higher, and the ramp rates are always faster than a flat tappet cam so make double sure you do a piston to valve clearence check with clay, and I really suggest doing it on all pistons unless you have massive amounts of clearence.
Oh and don't use cheap rockers either, they can't take the spring preasures required for a solid roller cam, my closed preasure is higher than some peoples open preasures on a flat tappet, and I run over 800lbs of open preasure if that gives you and idea.
homer4111
06-08-2006 06:13 AM
The Freak
16
03-22-2006 10:42 PM
0270
10-09-2004 12:25 PM
