How to change te freeze plug? - Ford Truck Enthusiasts Forums
Old 04-09-2007, 09:46 AM
DJdemon6696 DJdemon6696 is offline
DJdemon6696 is starting off with a positive reputation.
Question How to change te freeze plug?
1990 351W
how difficult is it to change a freeze plug.. the 2nd one behind the oil filter under the exhaust manifold thanks..
J.J
Old 04-09-2007, 07:33 PM
HemiEater's Avatar
HemiEater HemiEater is offline
HemiEater is starting off with a positive reputation.
get a rubber one...you wont get a metal one there...will maybe you can but I can't, I use the rubber ones just push them in and tighten the wing nut.. Done...If the motor was out I would use the normal plugs but in the truck it tough...
Old 04-09-2007, 07:36 PM
acheda's Avatar
acheda acheda is offline
acheda is gaining momentum as a positive member of FTE.
How easy, or how to do it? Easy if the engine is out, hard if it is in.
For a one-shot job, sharpen an old large screwdriver to form a chisel. Tap it through the core plug (aka "freeze" plug); then bend it sideways and the core plug should pop out. Be careful not to just knock the core plug inwards. (If you have doubts find an old junk engine to practice on or ask an automotive machine shop to let you watch removal of core plugs.)
In the engine is in the vehicle, it will probably be necessary to support the engine's weight and remove the motor mount and prehaps the exhaust manifold. A new core plug will have to be coated around the rim with sealer and installed in its bore. Pro's use a tool, but any blunt object can be used as a punch and then it will take many, many small taps with a hammer and the "punch" to drive the core plug home without cocking it at an angle. (Go around & around the edge of the new core plug.) There are rubber expanding plugs for "emergency" repair, which will make the installation easier.
Old 04-13-2007, 10:24 AM
thanks for all the help.!! the new freeze plug is in and she's running again
Old 04-14-2007, 06:03 AM
HemiEater's Avatar
how did you do it and what kind did you use? just wondering cause I could never get the metal ones in with the motor installed.
Old 04-14-2007, 08:14 AM
i used a metal one...
step 1 = remove the tire put the car up jackstand of course
step 2 = hold the motor in place with a jack and a 2X4
step 3 = onscrew the moter mounts ( jack the motor ) try to remove the mount( it did not remove it but move it a side jest enough to reach the plug
step 4 = take the old one as you wish hamer it with a screw drive than pull it with a ply out
step 5 = clean the hole and the buildup around it good!!
step 6 = clean the new one put teflon paste around it ... i used a extension with a big enough socket end tho hamer it gently in place and then youre done
Hell of a work tho ! but she's running again
THE PICS
Before ( the busted one ) in place
[/img]
The plugs ( the new one the wall is much ticker )
[/img]
[/img]
the job when complete
[/img]
Old 04-15-2007, 07:27 AM
HemiEater's Avatar
looks crooked to me hope it stays in there.....
Old 04-15-2007, 07:37 AM
acheda's Avatar
Look at the picture above comparing the new & old core plugs. The universal replacement core plug has much more depth, so it is in plenty deep. It may even be bottoming out.
I congratulate DJdemon6696 on completing a tough job - well done!
Old 04-15-2007, 08:14 AM
HemiEater's Avatar
it's tough alright....I could never get them in....well done.....
Old 04-15-2007, 11:07 AM
thanks.. and yes it did bottom out,, thats why it looks like that..
Freeze plugs bass-n-fire 1994.5 - 1997 7.3L Power Stroke Diesel 0 12-29-2016 02:37 PM
How can i blockoff all intake coolant wedge542 6.0L Power Stroke Diesel 7 04-23-2016 08:25 PM
1990 aerostar freeze plugs tk1251k Aerostar 46 05-31-2014 10:28 AM
Freeze plugs leaking. 77f250weos 1973 - 1979 F-100 & Larger F-Series Trucks 18 09-21-2013 01:48 PM
freeze plugs? brass or steel?? vanmannj Cooling, Heating, Ventilation & A/C 3 11-01-2004 08:27 PM
Tags
289, 351, 40, cam, coated, engine, ford, freeze, galley, location, locations, oil, plug, plugs, rubber
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
