2001 Ranger: Flashing "O/D Off" light
Old 04-09-2007, 09:19 AM
seismojones's Avatar
seismojones
seismojones is offline
Hey, guys.
I have a 2001 V6 4.0L Ranger with automatic transmission.
The last few weeks my Ranger seemed to struggle a little when the engine switched to 2nd gear. It seemed that it went a little longer before switching gears - the tachometer seemed to a little higher but not dangerously. I wasn't sure if it was just something in my head or not so I ignored it as it didn't really seem to be a problem.
This morning on the way to work, my overdrive light started blinking - it's the "O/D Off" light on the dash. It blinked all the way to work and I noticed that now when the engine goes into 2nd gear, it's more of a jerk than a smooth transition. The higher gears seem fine - no problems at all but the "O/D Off" light continued to blink. I pressed the overdrive button on the gear shift (do you still call it a gear shift on an automatic?) repeatedly but it had no effect.
Any ideas?
I did a search here for "O/D Off" but no hits came up.
Any help would be most appreciated.
Old 04-09-2007, 10:40 AM
aquanaut20's Avatar
aquanaut20
aquanaut20 is online now
This indicates that the tranny has gone into limp mode, get the codes pulled and post.
Old 04-09-2007, 11:54 AM
reddog99's Avatar
reddog99
reddog99 is offline
And check the oil level.
Pat
Old 04-09-2007, 12:11 PM
seismojones
Ironically enough, I just changed the oil yesterday. I checked the level when I got to work today since that seemed like a strange coincidence but it was fine.
Old 04-09-2007, 01:07 PM
fordboy_52's Avatar
fordboy_52
fordboy_52 is offline
hrm, the 4.0l trans has had some issues. not as many as a 3.0l though. i am curious if you have engine braking in manual first gear?
Matt
Laneely84
10-27-2015 05:12 PM
karkraft55
12-22-2005 06:54 AM
NascarNut
1978 - 1996 Big Bronco
07-09-2004 11:00 AM
keepkoolac
1999 to 2016 Super Duty
05-23-2004 09:33 AM
mrminn
03-15-2004 07:19 AM
Quick Reply: 2001 Ranger: Flashing "O/D Off" light
