Can I swap a XLT instrument cluster for a FX4 one? - Ford Truck Enthusiasts Forums
Old 04-08-2007, 09:47 PM
F150ny F150ny is offline
F150ny is starting off with a positive reputation.
I've search for over an hour and all I could find was swapping a Lariat instrument cluster to an XLT, STX, or XL and all of the problems that go along.
Well, I have a XLT but I want to switch to the FX4 instrument cluster. Is this possible? Other then getting the miles programmed, is there anything else I should be aware of?
<O
Will my P.A.T.S. work?....will the truck start? <O
Will all of my XLT functions work?...i.e. A/C, dome light fade, door/key chime, 4x4, etc. I was told that they won't if you don't program my XLT cluster into the FX4 one....is this true?<O
Thanks for the help.
Old 04-08-2007, 10:57 PM
HomerWinzlow's Avatar
HomerWinzlow HomerWinzlow is offline
HomerWinzlow is gaining momentum as a positive member of FTE.HomerWinzlow is gaining momentum as a positive member of FTE.
Anytime you change the cluster, even to put the same type cluster in, you have to have a Ford scan tool to do a Programmable Module Installation (PMI) with either the data retrieved from the original module or programmed with as built data only avaliable from a secure Ford website for technicians, PLUS you must either do a parameter reset and/or reprogram two keys.
Now there may be work arounds from the underground but that is what you are supposed to do.
That is aside from needing the module set for correct odometer reading.
Old 04-10-2007, 03:12 PM
kurtg3026's Avatar
kurtg3026 kurtg3026 is offline
kurtg3026 is starting off with a positive reputation.
I wish it was a easy thing to do, I would really like to have the FX4 gage on my XLT.
Old 02-01-2008, 08:41 PM
Joe04F150 Joe04F150 is offline
Joe04F150 is starting off with a positive reputation.
I only agree with needing the dealer to reprogram the mileage b/c it will register whatever is showing on the gauges. Other than that the only thing you need to do when swapping the clusters is disconnect the battery and swap out. Everything else works just fine, no programing keys or sensors.
Not sure if a truck that came with no tach (XL)will accept a cluster with a tach (XLT, FX4 etc..), but a FX4 cluster will definately fit in an XLT.
Old 04-13-2014, 09:36 PM
Billy Colman Billy Colman is offline
Billy Colman is starting off with a positive reputation.
I know this post is OLD... but I want to do the same thing. Forgive me for asking this, but are you completely sure that the FX4 will work in an XLT truck??? I've heard lots of people saying that there are issues, but of course, I'm hard headed. IF I can find an FX4 cluster, I would love swapping mine for it. If I swapped it out, and it doesn't work, will sticking my old one back in cure it?? Last thing I need is my truck not starting again! Lol! Oh, and what about the numbers associated with each cluster type... are there specific ones that will swap out easier? I believe these numbers are located on the sicker under the shroud on the cluster...
Thanks for any info you might be able to give me here.
Old 11-22-2014, 01:20 PM
KINGS11's Avatar
KINGS11 KINGS11 is offline
KINGS11 is starting off with a positive reputation.
xlt cluster to Fx4
I just replace my 2007 f150 XLT cluster with a FX4 and had no problems.It was plug and play. Everything work just fine.No programming needed.Take's about an half hour to do.I also change the stock black face to white.I took the time to sand off the green tint so that it would light up white.I installed white leds and it looks great.
Old 11-30-2014, 08:27 PM
tbear853's Avatar
tbear853 tbear853 is online now
tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.
Quote:
Originally Posted by KINGS11 View Post
http://cimg9.ibsrv.net/gimg/www.ford...7225ff47ee.jpg
http://cimg6.ibsrv.net/gimg/www.ford...56b82fcca7.jpg
I just replace my 2007 f150 XLT cluster with a FX4 and had no problems. It was plug and play. Everything work just fine. No programming needed. Take's about an half hour to do. I also change the stock black face to white. I took the time to sand off the green tint so that it would light up white. I installed white leds and it looks great.
Sand off "green tint" where exactly I wonder?
I prefer black faces and white numbers, etc .... but that's just a personal preference thing .... and it's not saying the white face looks bad because it looks great on that set .... but I really like the night shot.
Old 05-15-2016, 12:38 AM
CrimsonNinja666 CrimsonNinja666 is offline
CrimsonNinja666 is starting off with a positive reputation.
My XL f150 has a built in tach. Hold the trip reset button before you put the key in, keep holding it as you put the key in and start it. flip threw a few options and a digital tach comes up. Gotta do that every time. So i know i have a tach sensor, just not on the cluster.
Old 08-02-2016, 11:31 PM
Rickf15083's Avatar
Rickf15083 Rickf15083 is offline
Rickf15083 is starting off with a positive reputation.
did you make the swap at the end.
the trouble your talking about was with the lariat digital climate control.
ac wouldnt work.
i did mine no problem just the millage changed.
Old 08-07-2016, 08:59 PM
CircuitBoardMedics's Avatar
CircuitBoardMedics CircuitBoardMedics is offline
SPONSOR
CircuitBoardMedics has a very good reputation on FTE.CircuitBoardMedics has a very good reputation on FTE.CircuitBoardMedics has a very good reputation on FTE.CircuitBoardMedics has a very good reputation on FTE.
We can correct the mileage to be accurate on the new cluster if you want. Just call us at 800-547-2049 if you want to talk through the options.
Old 08-07-2016, 09:49 PM
Rickf15083's Avatar
Quote:
how go to the dealership. the millage is only 25 000km off from the motor its not all that bad for me
2000 Ford Expedition xlt battery saver relay clicking no start websurfer Expedition & Navigator 13 11-14-2016 03:22 PM
Cluster Trouble Motorcityiron 1997 - 2003 F150 11 04-04-2015 10:17 AM
No start 96 Ranger 4 cyl 2.3 5 jpj64 Ranger & B-Series 25 05-24-2010 09:58 PM
Ford 5.4 liter codes 171 & 174 THEN 401 & 171 Lugnut2008 Modular V8 (4.6L, 5.4L) 5 11-09-2007 02:57 PM
New 2006 offer from dealer, need advise Technocrsr 1999 to 2016 Super Duty 25 02-17-2007 10:13 AM
Tags
08, 2007, change, cluster, f150, functions, fx4, instrament, instrument, interior, light, navigator, reset, swap, work, xl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
