I received my edge evolution today. I plug it in and its set back to level zero as it should be, but it says its needs an update to work on my vehicle (somewhere along those lines anyway).
My problem is the fusion software says i have an unrecognized device. I've run the program on my pc in config mode and nothing changes. Restarted my pc to no avail.
unplug from port and replug mine does say my vehicle does not have the right calibration and i unplug plug it and it fines the old files and try putting it back factory
I called edge and they told me I bought a programmer that is too old and can't be updated to work with my 08.
As did I! But I called them and they busted that myth.
do you have the model number wondering if its the same as mine.
when i update my tire size sometimes i get and error but so far just unplug it and start over the tune and im ok
