ever burn aviation fuel in your power stroke?
So what do you think would happen if I burned JP-5 aviation fuel in my 7.3L I know the fuel has a tendency to act like a solvent and may break down some build-up in my fuel system, similarly to biodiesel, but I'm curious to see how it would run.... I would certainly use diesel-kleen or similar for lubrication additive. hmmm
From the Defense Technical Information Center's website:
"None of these tests showed engine failures or excessive wear attributable to the use of kerosene-type aircraft turbine fuels, although slightly reduced fuel injection delivery volumes and lower power output were experienced in most engines, due to lower viscosity and lower heat content of JP-5 and JP-8 compared to DF-2."
In other words, less power and worse fuel economy. Not to mention higher cost, I'm sure.
Sounds like I'm not the only one that can get his hands on some free JP-5. I only come across a gallon or so at a time that would normally get disposed of in a waste tank. I'll definitely start giving it a whirl. I know its a more refined fuel and would result in less power and efficiency, but free fuel is free fuel. I could fuel my truck for life with the amount of fuel that ends up wasted in my place of business.
Only fuel that is "certified" can go into an aircraft. If, for any reason, you need to take fuel out of it, it cannot be put back into the plane without extensive additional, again certified, filtration. It's almost always easier and cheaper to just dump it or give it to employees than to set up the holding and filtration necessary to re-use it. Only the VERY largest service facilities will make the investment necessary to re-certify the fuel.
Any lessor place (most any FBO) that services aircraft has some kind of fuel dump that they otherwise just have to pay to have hauled off.
And yes, you are correct, a lot of this is just "sumpings" that have to go somewhere, but anyone with a 55-gallon drum and a pump, filter, and water separator can refine it well-enough to use in a truck.
Besides, what comes out of a jet aircraft's tanks is already a lot cleaner than what you'll pump down at the local truck stop. Remember, not too long ago, it was "FAA Certified" clean.
Pop
Pop
As an aircraft refueler for 2 years, we ran all of our diesel trucks on Jet A. Jet A is what you will get at you airports. Los Angeles busses run on it because it burns cleaner. Jet A is a highly refined diesel, as for filtration, it is filtered when it is loaded on to the tanker that brings it to the airport, it is checked for impurities prior to the truck dropping its load then, filtered when we load the aircraft fuel trucks, and filtered once more as it is pumped in the plane. Oh, have you checked the price per gallon for Jet A? Its quite pricy!
