Where's the VAC INTAKE HOSE for SEAFOAM ??? - Ford Truck Enthusiasts Forums
Old 04-08-2007, 03:45 PM
kev100 kev100 is offline
kev100 is starting off with a positive reputation.
Question Where's the VAC INTAKE HOSE for SEAFOAM ???
98 XLT....SOHC 4.0 engine
Folks,
I'm needing to run some Seafoam through the manifold(?) system. I've added it to the oil for cleaning and now I need to do the other.
Well...from what I've read, you can use either the PCV hose or the brake booster hose to suck the stuff in...
Problem is...I can't make heads or tails out of all those hoses.
I see the diagram sticker on the left front under the hood...but that does not help much.
Is the brake booster hose easier to get to? If so (or not)...can anyone describe where exactly the hose to use is....and...once located...which END I disconnect to pour in the SeaFoam?
Any help greatly appreciated.
Kev100
('98 XLT - SOHC 4.0 6cyl)
Here are the generic instructions :
With engine warm, slowly pour 1/3 to 1/2 pint through carburetor or throttle body throat. (If vehicle is port injected slowly pour SEA FOAM through direct manifold vacuum line that will feed all cylinders, possible sources are P.C.V. valve or brake booster line.) This will pull SEA FOAM down on top of the pistons and to the back of the intake valves to dissolve carbon. Turn ignition off. Restart engine after 5 minutes. If severe carbon build up is apparent, use more Sea Foam as previously directed. Make sure exhaust is well ventilated when using Sea Foam in these various ways as fumes will be extreme for a short time.
Pour 1/3 to 1/2 pint into oil crank case to clean rings, lifters, dirty parts and remove moisture.
Pour 1/3 to 1 full pint into fuel tank to clean injectors, carburetor jets, fuel lines and remove moisture.
Immediate Results: Smoother idle, increased R.P.M.'s better throttle response and improved performance.
Old 04-08-2007, 04:11 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
the brake booster is the big round thing behind the master cylinder.
find the thick hose attached to that.
pull it off there and slowly pour into hose, i use an old starbucks cup.
do 1/2 can either make it stall or have assist shut off.
let it sit for 15 minutes or more.
will smoke like a motha so beware.
drive it around using low gear and stating and stoping to clean out.
than do second half of the can and repeat the drill.
do not leave it in the oil too long.
Old 04-08-2007, 06:12 PM
Is that (the brake booster) on the back right of the engine compartment as you are facing the windshield (with the hood up)?
If so....
I pull it off where it goes into the brake booster.
With the engine running...pour in half a can.
Will it stall by itself....or will I have have to shut it off (me or someone) to get it to stop?
Once it is stopped.....should I re-attach the hose immediately....then let it sit for 15 min?
Thanks very much.
Old 04-08-2007, 07:06 PM
quicklook2's Avatar
drivers side.
sometimes it stalls or shut it off quickly.
reattach the hose and go have a coke or lunch.
i let it smoke a bit going up and down the rpm range, not past redline, than i go for a drive.
usually in 1st gear up to like 400 rpm, than i stop and repeat a few times.
than i go for a drive with trands in drive for like 5 minutes.
than i repeat the process.
Old 04-28-2007, 12:41 AM
Thanks for the feedback. I gave it a try a few days ago....easy as pie....after I knew what to pour where.
Couldn't help but feel a little nervous at first...pouring flammable liquid down a vacuum hose.......it stalled.....waited about 20 minutes.....held my breath on restart...but it cranked right up. Smoked like a dog....putted around in Low gears for a minute then took it out on the road.......looked like a yayhoo driving around an oil burner....but it cleared up after a few miles......came back and changed the oil for good measure (I heard it's a good idea to change the filter afterwards).
All in all...no problems...worked like a charm.
Thanks
Old 04-28-2007, 09:47 AM
quicklook2's Avatar
do you notice that it runs better?
any vehicle i use it on does.
Cleaning of throttle body and upper intake with Sea Foam JSDSM 2007 - 2014 Expedition & Navigator 0 04-22-2016 08:04 PM
V10 PCV valve/sea foam? jleo 1999 to 2016 Super Duty 24 01-05-2013 02:37 PM
misfire and sea foam Mikeymoe Explorer, Sport Trac, Mountaineer & Aviator 10 02-26-2012 07:30 PM
what are your feelings about the miracle cure known as seafoam? mfp4073 Ranger & B-Series 2 06-01-2008 02:58 PM
SEAFOAM in OIL Procedure ??? kev100 Oil & Lubrication 2 09-22-2005 11:14 PM
Tags
0408, 2006, booster, diagram, explorer, f150, foam, ford, hose, intake, pcv, reattach, sea, seafoam, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
