Help with Identifying EEC-IV
I pulled the codes on my 94 150. Im getting code 211, 311, and 632. Code 211 is the one im most concerned about right now. It says " two or more PIP pulses occured - possible ignition miss or stall". In the Hayne's manual it says to run through a series of tests to help isolate the problem. It says to "disconnect the EEC-IV PCM from the PCM." This is where im getting throw off. I dont know where to find this connection to continue with my diagnosis. If anyone knows where this is located or has an exploded view or diagram, that would be awesome.
lildrummer420
33
11-28-2023 03:36 PM
CNTHOR
08-24-2002 07:50 PM
