Positive Ground Help, I messed up...
Which post is connected to the battery should matter in this case; see below. (Diagram is for '48-'49). One side of the pull-in coil is fed by the battery, the starter button grounds the other. Actually this answers the question why mine works as-is; my starter button is set up to send power to the solenoid (it doesn't ground the connection). Hmmmm.... I need to get under there...
Update: I checked my solenoid with an ohmmeter. It must be a late-50's model, i.e., for 12v. The two big terminals are interchangeable and completely isolated from everything, neither feeds the pull-in coil. I have to send +12v to the solenoid terminal to get anything, and it is grounding thru the mounting tab. This solenoid was on the truck when I bought it, looks pretty old, and was in use when the truck was still 6v.
Moral of the story: PO's do many wonderful things to vehicles. Before you assume what you've got, check it out!!
I found the same thing when I checked my solenoid, and the evidence showed when it started as a negative ground. So I'm guessing mine is also newer than 1948.
I bench tested my starter and it's not working. I don't know much about electric motors so I'm going to find a rebuilder tomorrow and hopefully get some positive results. I can't wait to get my truck running again.
fordguy2100
02-16-2017 10:03 PM
brian1985f150
19
02-07-2017 05:52 PM
harleyclassic
02-11-2004 12:04 AM
