Outside truck temp. gauge ?? - Ford Truck Enthusiasts Forums
Old 04-06-2007, 09:39 PM
K.O-T.O K.O-T.O is offline
K.O-T.O is starting off with a positive reputation.
When I replaced my brakes I also disconnected the battery thinking it would reset the brain. Well now the outside temperature reads between 94 to 105 deg. It is only 55 to 65 degrees. Is there a way to recalibrate that thermistate? I tried the trip calibration but it only effects the gps. I wanted to reset the brain because the pedal responce seems to be poor. It might just be a timeing issue. Thanks for your input.
Old 04-07-2007, 12:57 PM
elite64a elite64a is offline
elite64a is starting off with a positive reputation.
replace the OAT gauge
O= outside
A=air
T=temperature
Old 04-07-2007, 01:02 PM
HomerWinzlow's Avatar
HomerWinzlow HomerWinzlow is offline
HomerWinzlow is gaining momentum as a positive member of FTE.HomerWinzlow is gaining momentum as a positive member of FTE.
Have you driven it since you reset it. Drive around for about 5 mins over 35mph and see if it normalizes.
Old 04-07-2007, 03:01 PM
nascar6dude nascar6dude is offline
nascar6dude is starting off with a positive reputation.
I agree. Whenever you disconnect the battery, it takes time for the computer to "relearn" it's settings,hence your poor pedal response. Drive it around for 5-10 minutes at moderate speed (don't horse it) to give the computer time to reset itself.
Old 04-07-2007, 08:11 PM
The pedal responce is better but for some reason the temperature gauge still reads around 40 degrees hotter for about three weeks know.
Old 04-10-2007, 03:37 PM
kurtg3026's Avatar
kurtg3026 kurtg3026 is offline
kurtg3026 is starting off with a positive reputation.
Thats golbal warming for you!
Old 04-10-2007, 08:31 PM
fsjosh fsjosh is offline
fsjosh is starting off with a positive reputation.
I had the same problem with the temp gaugue, but it didn't have anything to do with disconnecting the battery. I had to take the truck in for an unrealted service issue and had them look at it. They said the sensor was bad and replaced it. Problem solved.
Old 04-09-2014, 08:38 AM
andykurz andykurz is offline
andykurz is starting off with a positive reputation.
Old thread here, but I was wondering if there was a way to calibrate this sensor too. I guess I will just drive around a bit.
I bought a new (to me, 2004) truck, gauge was reading consistently 10deg low. So I searched around, decided to order a new sensor, added it, and I am still 10deg low. Said 44 degrees in my garage yesterday, it was probably 54 degrees.
Just curious if there is any way to calibrate that anyone might be aware of.
Old 04-09-2014, 06:28 PM
CaptFX4 CaptFX4 is offline
CaptFX4 is gaining momentum as a positive member of FTE.
No way to calibrate it that I know of. Mine was reading 15 degrees high. I just replaced it last week with a BWD model from O'reillys and it's been working fine ever since.
Only thing to calibrate would be compass if that's off.
1999 E250 won't start yzoldowl 1968-2013 Full Size Vans 3 03-03-2015 11:24 PM
Replaced VSS & ABS Wheel Speed Sensor and speedo still not working JB1rd 1997 - 2003 F150 10 02-23-2014 10:33 AM
Radio Issue eazrider Excursion - King of SUVs 4 09-24-2013 04:00 PM
Random sputter then a stop Dillon20 1987 - 1996 F150 & Larger F-Series Trucks 1 08-20-2013 09:23 PM
Help with 6.8 shuddering/ misfire???? elitedc Modular V10 (6.8l) 7 01-30-2006 08:34 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
