need more info on the hood flip
AX, the pic is of very awsome 56 that I saw at the annual "all ford " show at the Ford dealer 2 years back. The entire truck is rad and I thought the flipper was real different and I take pics of anything that lifts my skirt. Have not seen again, never found owner. The eng & comp is way big,and crazy too. Jon
Originally Posted by CIAF
just look at Randy Jack's unit, Whoa............They are innovators and craftsmen that cross the threshold of engineering marvel and craftsman in ways that I can't achieve,
Hey guys , I thought I would touch base and let you know how the flip is going . After I got off to a bad start ( went ahead and started fabbing things up without some base measurements to go by BIG MISTAKE ) . After having to back track abit the front flip part is almost done . Now on to the guide part for the rear rollers . I do want to give a BIG thank you to fatfords .Your diagrams were a big shot in the arm . I used them as a guide and everything worked out well . I did incorporate some different measurements and such because I am using a stock latch panel with a 1978 f250 radiator . But for the most part you were right on the money . I will see if I can get some pics posted sometime in the next few weeks .
carnut122
01-04-2011 04:57 PM
Julies Cool F1
25
09-02-2009 03:55 PM
Frenchy
09-01-2008 06:39 PM
