Go Back   Ford Truck Enthusiasts Forums > Diesel > 4.4L Ford Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
4.4L Ford Diesel Discuss the much rumored 4.4L Ford diesel engine
Is F-150 Still King?
  #46 (permalink)
Old 04-16-2008, 08:28 PM
parkland's Avatar
parkland parkland is offline
parkland is gaining momentum as a positive member of FTE. parkland is gaining momentum as a positive member of FTE.
manitoba-
Thats a liter. As in 1.22 per LITER.
__________________
2002 7.3 PSD 4x4 Nothing out of the ordinary.
  #47 (permalink)
Old 04-16-2008, 08:31 PM
MisterCMK's Avatar
MisterCMK MisterCMK is offline
1994 Ford Mustang
My Garage
MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold MisterCMK is a splendid one to behold
So that would be around $4.61 USD per gallon for gasoline and $4.69 USD per gallon of diesel. I am surprised that they are that close.
__________________
Chris
1994 Mustang GT
1992 Explorer XLT
2000 Expedition EB
http://mistercmk.com/images/sig.jpg
Quote:
Originally Posted by tcbofade
I have no brain
  #48 (permalink)
Old 04-16-2008, 08:53 PM
parkland's Avatar
dont be suprised about nothing man, I recently stopped workin in the oilfield. One thing i'll tell you is that whenever prices go lower, they just stop pumping. they make their own "demand".
__________________
  #49 (permalink)
Old 04-17-2008, 02:29 AM
mnmwhit's Avatar
mnmwhit mnmwhit is offline
mnmwhit is starting off with a positive reputation.
I don't think they would make enough power for the EXPY (too heavy) but great power plant for the Sport Trac, Explorer, Ranger, hmmmmm Ford 500 maybe?
Quote:
Originally Posted by jmaskew View Post
Here's the specs"
The 2.5L Engine gets 28.7 mpg
The 3.0L Engine gets 26 mpg
Wouldn't these engines be great in the Ford Explorer and the Expedition?
__________________
06 F-350, North Pole, Alaska
Brush Guard w/4 moose lites
Mobil-1 Turbo diesel truck oil
fuel filters every 10,000 miles
AstroStart auto start
98 gal Transfer flow tank
Rhino liner on the rockers
Wabasto-Blue heat
MBRP turbo back duels w/ no CAT
  #50 (permalink)
Old 04-17-2008, 08:56 AM
jmaskew's Avatar
jmaskew jmaskew is offline
jmaskew is gaining momentum as a positive member of FTE. jmaskew is gaining momentum as a positive member of FTE.
Quote:
This is a bit off topic, but take a look at this article. It's interesting to see how many miles you can squeeze out of a diesel engine.
Toyota Ireland - D-4D Clean Power
__________________
^Camping at ZION NP, Utah^
Jonathan
2004 F250 PSD SB King Ranch 4x4:Build Date: 01/23/2004
Dieselsite Coolant Bypass Filter, High Idle Mod
Fumoto Oil Drain Valve, Harpoon Mod, Zoodad
Isspro 40 PSI Boost, Water Temp, Oil Temp and Trans Temp
  #51 (permalink)
Old 04-18-2008, 02:30 PM
parkland's Avatar
Everyone has HP ratings buzzing in their heads nowadays. Look at the old 70 passenger school buses and other large vehicles powered by 6.9idi, 7.3idi, cummins5.9, all had 150-180 hp and they got the job done.
Ford should build a reliable, easy to service engine, that gets good fuel mileage and decent power, but leave the 300+ hp tunes for enthusiasts.
__________________
  #52 (permalink)
Old 04-20-2008, 12:59 AM
bookem15 bookem15 is offline
bookem15 is starting off with a positive reputation.
I could not agree more BUT they will not do that HP sells now days. If the people at ford that are going to design these engines had a job that they needed a truck for but did not make the money they make now I would have to say the the MPG's would be more of a concern.
__________________
Drive it like ya stole it !!!
2004 F150 extra cab 4X4
85,000 miles 4" lift and level
Next truck
2011 F350 cc 4X4
  #53 (permalink)
Old 04-20-2008, 09:19 AM
origcharger origcharger is offline
origcharger is gaining momentum as a positive member of FTE. origcharger is gaining momentum as a positive member of FTE.
Excuse me but our first diesel was a 1985 International 6.9idi with a 59 passenger bus body. It had something like 165 hp and about 320 ft lbs of torque. With a 6.50 to 1 axle you had it reving like a gas engine to go anywhere. It was marginal on power empty, pathetic fully loaded and stay away from the hills. Fuel mileage was an improvement over gas but not that impressive. It never got more than 500 miles without using a quart of oil and consumption got bad enough that IH rerung it just before it went out of warranty around 50,000 miles. It dropped a valve at 100,000 miles and split a cylinder wall. Put a reman engine in it and it had a roller cam follower disintegrate at 50,000 miles. Last I saw the bus it was on its way to salvage yard.
__________________
2004 E-450 6.0 139,000 miles
7,500 mile, 15 quart oil changes, 5W-40 Rotella.
UOAs consist of checking for metal on drain plug magnet. All stock, no mods. Dyed fuel with no additives. Never been reflashed.
Total parts replaced;
one EGR valve.
  #54 (permalink)
Old 04-20-2008, 02:13 PM
iwannaford iwannaford is offline
iwannaford is starting off with a positive reputation.
the 6.7 cummins is actually 350 H.P and 650 torque
  #55 (permalink)
Old 04-20-2008, 03:56 PM
AndysFords AndysFords is offline
AndysFords is starting off with a positive reputation.
The problem with all these new engines is they are trying to squeeze too much MPG and HorsePower out of the same engine, the also choking it down with emissions garbage on top of that.
__________________
1997 F250 Crew Cab 4x4----
1997 Dodge 2500 4x4 Cummins Automatic
1988 F350 7.3 Crew Cab 4x4 Dually C6
1984 F250 2 wheel drive 6.9 Extended cab 4 spd manual.
  #56 (permalink)
Old 04-25-2008, 08:50 PM
ncl ncl is offline
ncl is starting off with a positive reputation.
Why is Ford hell bent on putting a diesel in the F150 no one wants to buy a diesel now cause of the price, As was said in an earlier post the cost difference in fuel out weighs the mpg increase not to mention the cost for oil changes. I dont want to start anything but I think all this sudden rise in fuel prices the last few years is a ploy by are Almighty Government, to one make money, and to force the going green thing down all our throats. I hate to say it but this whole fuel crisis started on 9/11/01 the price shot up I think 20 or 30 cents cause every one was scared and rushed to the pumps and stores just seems to snow ball from there involving other Global Conflicts. Just makes you wander huh? "It's big s@*t sandwich and we're all gonna take a bite"
__________________
NATRON
1977 F150 Ranger XLT 4x4,400
  #57 (permalink)
Old 04-25-2008, 10:41 PM
Quote:
Do you really know how much oil changes will cost on a diesel F150?
__________________
one EGR valve.
  #58 (permalink)
Old 04-26-2008, 09:43 AM
ncl ncl is offline
No I dont but diesels usually take about twice the amount of oil a gas engine does. My fathers 6.0 stroke takes about 4 gallons of oil so maybe the 4.4 maybe 2.5 to 3 gal maybe.
__________________
NATRON
  #59 (permalink)
Old 04-26-2008, 12:47 PM
Our 6.2 GM diesel took 7 quarts.
__________________
one EGR valve.
  #60 (permalink)
Old 04-27-2008, 12:15 AM
kermmydog's Avatar
kermmydog kermmydog is offline
1986 Ford F-250
kermmydog has a great reputation on FTE. kermmydog has a great reputation on FTE. kermmydog has a great reputation on FTE. kermmydog has a great reputation on FTE. kermmydog has a great reputation on FTE. kermmydog has a great reputation on FTE.
Smile
I also couldn't agree more. I would be nice if Ford built an I-6 that was easy to work on & reliable. I dislike the navstars all of them. The 6.9 early 7.3 weren't too bad.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
