Prerunner f250? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Prerunner f250?
Old 04-06-2007, 12:40 AM
kevin265 kevin265 is offline
kevin265 is starting off with a positive reputation.
Prerunner f250?
I'm not sure if this is the right forum but I'll give it a shot.
I have a buddy who going to be racing SCORE events. I have a 2wd F250 PSD. I thought it might make a great chase truck with the right suspension mods. Any ideas/opinions?
Old 04-06-2007, 07:56 AM
papadelogan's Avatar
papadelogan papadelogan is offline
Snowboard season cometh..
papadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to behold
2WD? Hmmmm... i don't know the courses that SCORE uses, or that you'll be running, but that would be my concern. Diesel Power did an article about a year ago on an F250 6.0 PSD that ran the Baja1000 (I believe) and this month's issue had one about 3 Dodge diesels running the Baja1000. So long as you won't need 4WD you're good to go, but if you have to go pull out/rescue/repair your buddy then you have to consider the terrain he/she is covering as well. I'd definitely invest in an AIS for your truck if you do do this.
Old 04-06-2007, 08:06 AM
bfife's Avatar
bfife bfife is offline
still plays with trucks
bfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to behold
Checkout Fabtech, they started out specializing in 2wd suspensions. ifYou can pick up an issue of Dusty Times, it will give you a lot of manufacturers that build products just for the offroad racers. As far as 2wd chase truck goes, invest in a locking diff, soft, long travel suspension and medium wide tires to let you float the sand and dust pits and it will work just fine. have fun Barney
Old 04-06-2007, 08:09 AM
I've never heard of Dusty Times but I want to check it out!!! Thanks for the info bfife!!
Old 04-06-2007, 02:02 PM
travis dasher's Avatar
travis dasher travis dasher is offline
travis dasher is starting off with a positive reputation.
Check out KORE or Donahue Racing suspension systems. The truck that Papa is referring to had a Donahue Racing suspension system it was however a 4x4.
Old 04-09-2007, 06:26 PM
Thanks guys for the info. My truck will be used to run form pit to pit carring parts. I wont be traveling the rough course but lots of dirt roads and well in the dark in Baja......... its good to be prepared for the unforseen ditch. I'll let you guys know how it works out. Thanks
Tow mirrors 79CAMOFORD 1999 to 2016 Super Duty 8 08-08-2016 04:28 PM
Wanted 1954 F250 Rear Fender Cabledude Ford Truck Parts for Sale 0 06-18-2015 12:08 AM
New Tires on F-250 Mantitoba-f250 1999 to 2016 Super Duty 4 08-23-2014 11:33 PM
2006 f250 psd pull to the right s91Ford 6.0L Power Stroke Diesel 13 11-28-2011 08:37 PM
1977 F250 brake light problems bcinutah 1973 - 1979 F-100 & Larger F-Series Trucks 3 08-31-2009 03:32 PM
Tags
06, 99, chase, donahue, f150, f250, ford, kit, power, prerunner, racing, sale, stroke, suspension, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
