explorer rearend swap
I just got a 97 explorer rearend w/disc breaks. My present setup is mopar frontend w/disc, stock rear w/drums. The booster and pedel setup is from a 85 F150 which seemed to work fine around the yard. My ?? is with the disc in the rear as well , will the same booster do the job ? Will I need to get a different proportioning valve or a different booster setup all together ? The truck is a 54 MERC. I'm not much of a poster but I read them every couple of days. I must thank many of you as I have been learning so much about my truck from this sight. This truck racket can get very $$$$$ and this info is just like scoring a major deal on a part you've been looking for.
TKS DAN
TKS DAN
Originally Posted by bkntym
Thanks Jeff
I was looking for a rearend and this one came up so I'll use it. What mst cyl and pro valve do you suggest ? Should I try to get the same one from the wrecked EXPLORER ?
Thanks Again DAN
Thanks Again DAN
