truck is sputtering!
Old 04-05-2007, 07:49 PM
99powerstrokeSD's Avatar
99powerstrokeSD
99powerstrokeSD is offline
On the way home tonight my truck started sputtering as I was driving down the road. It never died but it would sputter and jerk and then kep on going. The check engine light came on and stayed on but I do not have a way to check it myself. Does this sound familier to anyone? I had to replace the CPS sensoe 2 weeks ago, but then the truck died and would not start. I have no clue.
Old 04-05-2007, 08:18 PM
BoostRetard's Avatar
BoostRetard
BoostRetard is offline
Not sure if it's the same thing, but last week mine started running like crap. If seemed to not be getting fuel. It was running weak and was bucking as I accelerated. I thought maybe the pump, regulator, or injectors were going bad. I changed the fuel filter just to be sure it wasn't something simple. After doing that it wouldn't prime and wouldn't start. Checked the fuse and it was blown. Changed it and the truck has been running perfect. Never realy had a fuse partially blown. I'm still at a bit of a loss on it.
Uzumati's Avatar
Uzumati
Uzumati is offline
Was the tach dropping like you cut off the key when this was happening?
Old 04-05-2007, 08:22 PM
99powerstrokeSD
I was watching the tach as you told me when the CPS went out and it was not moving at all. But as BoostRetard stated it is just bucking like it was not getting fuel. Which fuse did you replace? Would the check engine light come on if t it was a fuse?
Old 04-05-2007, 08:23 PM
F350-6's Avatar
F350-6
F350-6 is offline
I'm not sure what you mean by sputtering, but when my CPS went out the truck would "cough" like an old gas engine and then continue to run fine for a while. The cough was like a small backfire through the carburetor that would cause a moments hesitation then the engine would pick back up like nothing ever happened. The light came on after the second time and stayed on. I took it straight to a mechanic and the code came back CPS. Hope this helps.
Old 04-05-2007, 08:29 PM
Uzumati's Avatar
Uzumati
Uzumati is offline
Check fuse 19 and 30
When you key on does the WTS light come on?
Old 04-05-2007, 08:35 PM
99powerstrokeSD
WTS light does come on and 19 and 30 look fine. The check engine light is now off though.
Old 04-05-2007, 08:47 PM
Uzumati's Avatar
Uzumati
Uzumati is offline
Is it starting now?
Do you hear the fuel pump coming on at key on for about 20 seconds?
Just to be sure check the CPS and make sure it is still tight and the connector is clean and the wire is not chaffed where it runs close to the pulleys.
Old 04-05-2007, 08:52 PM
99powerstrokeSD
It starts fine, it never did die on me just bucked going down the road. The CPS seems tight and pluged in good.
Old 04-05-2007, 08:53 PM
99powerstrokeSD
And yes you can hear the fuel pump kick on.
Old 04-05-2007, 08:59 PM
Uzumati's Avatar
Uzumati
Uzumati is offline
Possibly the under valve cover harnesses, do you have a way of ohming out the harness.
Old 04-05-2007, 09:00 PM
MAKO314's Avatar
MAKO314
MAKO314 is offline
these trucks will run with a dead fuel pump just not well and with the same symptoms you have described. if it is the oe fuel pump I would have somone check the fuel pressure. I just had to replace mine this past tuesday and it acted just like you are describeing, now it's running nice and healthy. just my .02 worth
Old 04-05-2007, 09:01 PM
99powerstrokeSD
I have no clue. I will have to take it to the shop and have them look at that.
Old 04-06-2007, 07:56 AM
99powerstrokeSD
This morning on the way to work the truck drove like a champ I have no idea.
Old 04-06-2007, 10:24 AM
BoostRetard
My check engine light did not come on. I may still replace the pump just to have peice of mind. Something caused the fuse to blow. That isn't that normal. I can't remember which I replaced. I think it was 19 or 30. It was a yellow 30amp under the hood. Truck is running perfect since it was changed.
Quick Reply: truck is sputtering!
