FE freeze plug diameter - Ford Truck Enthusiasts Forums
Old 04-05-2007, 02:49 PM
hoxiii's Avatar
hoxiii hoxiii is offline
hoxiii is gaining momentum as a positive member of FTE.
Allright, i was wondering if all 6 block plugs on a '64 390 are the same size or not.
I had one blow out on me so I put one of those rubber expanding ones in there to get myself home, but i started thinking that if I'm going to have to put a plug up in there anyway i might as well put an engine block heater in while I'm at it.
Deal is, all the ones I can find say they should be installed in the right center plug. Issue here is 1) it's not the one that came out and 2) there is no way a block heater could go in there due to the motor mount.
Do they just recommend to put it there for efficiency's sake, or is the center plug a different size from the others?
The one that came out is the right front on and i know for a fact it's a tad over 1 3/4" (1 49/64").
Justin
Old 04-05-2007, 03:16 PM
FFR428's Avatar
FFR428 FFR428 is offline
Needsmorecoffee.
FFR428 has a good reputation on FTE.FFR428 has a good reputation on FTE.
All 6 plugs should be the same size. And yes 1 49/64" is the correct size. I think the new Dorman brand plugs they sell for the FE are 1/3/4" a hair smaller and really not the right size. I have an used set of newer Dorman plugs out in the tent I'll dig them out an measure them if you like. Or someone might confirm the size that has one on hand.
G.
Old 04-05-2007, 03:40 PM
hoxiii's Avatar
Yeah, the plug that shot out was a Dorman 1 3/4" replacement. I replaced them all prior to putting the motor in and hadn't noticed this plug said clearly "1 3/4" on it. The other 5 are actually the 1 49/64 plugs. I already broke the bank and bought the proper plug for all of $0.59 But again, a block heater would be a handy thing to have.
So if all 6 are the same size then the block heater directions were probably just for efficiency's sake like i was thinking.
Thanks!
Justin
Old 04-06-2007, 08:26 AM
FFR428's Avatar
Needsmorecoffee.
Justin did you find a 1 49/64" replacement? If so can you tell me where and what number? My Dorman catlog is REALLY old and if they now sell the right size plug again i'd like to make a note of it...
Thanks,
G.
Old 04-06-2007, 10:52 AM
hoxiii's Avatar
dorman 555-036, has 1 49/64 stamped right on it.
Justin
Old 04-06-2007, 04:58 PM
FFR428's Avatar
Needsmorecoffee.
Thanks!!
G.
Old 04-07-2007, 02:25 PM
aMoneypit aMoneypit is offline
aMoneypit is starting off with a positive reputation.
STEEL, oh no......
Quote:
Justin
That is the STEEL number, BRASS would be 565-036........Why would anyone bother to install a steel freeze plug?? It is already starting to rust!!!!!!! Use brass and do it once.............aMP
Old 04-07-2007, 02:34 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1965/76 FE's
C8AZ-6026-A replaced by >>> D7AZ-6026-A .. Core Plug~Std.-1.75 O.D.
C8AZ-6026-B .. Core Plug .030" O/S
Old 04-07-2007, 04:57 PM
FFR428's Avatar
Needsmorecoffee.
Quote:
1965/76 FE's
Wow interesting!!
G.
Old 04-07-2007, 08:08 PM
"Beemer Nut" "Beemer Nut" is offline
"Beemer Nut" has a good reputation on FTE."Beemer Nut" has a good reputation on FTE."Beemer Nut" has a good reputation on FTE.
I must add more fear here, at my local parts store that handle Dorman stock
many items have "CHINA" stamped on them.
Feel lucky?
Old 04-07-2007, 08:14 PM
Feel lucky?
Old 04-07-2007, 08:26 PM
FFR428's Avatar
Needsmorecoffee.
Feel lucky?
LOL ...Oh great!! Maybe they will be metric then?
G.
Old 04-07-2007, 09:45 PM
Ya might get lucky and get a metric size between 1 3/4" and 1 49/64" that might fit.
When installing just pound the rice (chit) out of 'em.
Everything but the house payments are paid in rice.
Old 04-08-2007, 01:48 AM
No RUBBER, or STEEL, USE BRASS......And install the right size DRY. Use a tool that drives on the outside lip, not the bottom of the "cup". (I use a bearing and seal driver set, or turn a custom tool on the lathe).............Get 'em straight and they almost fall in. BTW, if one rusted out the rest aren't far behind. ..........aMP
Old 04-08-2007, 07:36 AM
FFR428's Avatar
Needsmorecoffee.
I just use a big socket on em. I now use brass only also. On steel plugs I used to smear a thin coat of black RTV on the back and lip. This helped stop corrosion quite a bit. On my new block it has steel screw in plugs and I see they use sealer on the outside edge of those also.
G.
302 Engine Block Drain Plug dustmote 1987 - 1996 F150 & Larger F-Series Trucks 22 08-06-2015 10:00 AM
Heater core rcraft 1967 - 1972 F-100 & Larger F-Series Trucks 2 03-30-2014 04:55 PM
Removing starter and block plugs Sullid01 6.0L Power Stroke Diesel 16 08-05-2013 08:42 AM
85 6.9 Burns out glow plugs BlackDiesel85 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 24 04-11-2011 12:04 AM
Replacing the block heater. ttexastim Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 12-08-2010 12:12 PM
Tags
300, 352, 390, 565036, ci, diameter, dorman, fe, ford, freeze, frost, location, plug, plugs, size
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
