Failing Emissions (Nitrates of Oxygen)
I took my "1988" 5.0 liter Bronko through inspection and it is failing emissions.
I pullud the codes and with the KOER the codes are 44, 33, 13, and 52.
I set the timming, replaced the TAD/TAB solenoid and the EEGR valve and I continue to get the same trouble codes.
Can someone give me advice based on the above information?
Thanks,
JAB.
Thanks,
JAB.
Did you remember to clear the codes either before or after the work was done?
Dennis https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=1733&.jpg
Please Don't Ask Me Any Tough Questions As:
"I'm Saving My Memory For When I Develop Alzheimer's"
78 F-150 429CJ,Silver
w/Explorer Pkge.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon
w/Explorer Pkge.
84 Volvo DL Wagon
First I would disconnect the battery for a couple of minutes to clear the codes. Then go for a short test drive and check the codes again. NOX stands for oxides of Nitrate not Oxygen. NOX readings go up when combustion chamber temperatures go up. One of the biggest contributors to that is a faulty EGR valve.
code 13 engine running: RPM was wrong during low idle self test, check for vacuum leaks, idle air control operation and high minimum idle.
code 33 memory: EGR sensor signal did not change when the EGR was commanded to open. EGR intermittently did not open during normal operation
code 33 engine running: EGR does not open when the processor commands it to open. Check EGR vacuum line, solenoid operation and sensor operation.
What are your HC and co readings? Hope this helps a little
Randy..........
Randy..........
I took my truck back to the emissions station today. It failed again, the results are as follows.
Complete Test Second Phase
Standard Reading Result Standard Reading Result
1. HC grams/mile 3.2 2.86 Passed 2 2.62 Passed
2. CO grams/mile 80 23.69 Passed 64 24.39 Passed
3. NOx grams/mile 3.5 6.27 Failed 3.5 7.83 Failed
I removed the new EGR valve and found a large amount of carbon deposits at the inlet and the outlet of the valve. I cleaned it and removed the deposits.
I am now attempting to check the vaccum lines however, I do not know where I should see positive or negative pressure.
Any help in this matter would be greatly appreciated.
Thanks,
JAB.
Thanks,
JAB.
Bern_F150_4x4
05-02-2003 09:54 AM
