Old 11-18-2014, 05:14 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
Print Wikipost
Why does my truck shake like crazy when its in idle?
Old 04-05-2007, 12:29 AM
jodrayt's Avatar
jodrayt
jodrayt is offline
If i run my truck for a little while and sit in idle it shakes, if i give it gas while im at idle it shakes less, my check engine light is on and when it shakes bad the light blinks then stops blinking and stays solid. Any ideas?? Thanks
Old 04-05-2007, 03:24 AM
92F150Flare's Avatar
92F150Flare
92F150Flare is offline
Welcome to the forum
Need more info.....truck, motor "etc"
Did you just do a tune-up and cross some wires maybe? or hasn't it been tuned-up in a long time? Is it making any odd noises? Describe everything as best you can.
Did the check engine light come on at the time it started shaking or was it on before. Reading the codes will tell you why the light is on and point you in a direction to fix it.
Here is some info on the codes>
https://www.ford-trucks.com/article/...rocedures.html
Give more info and you'll get a lot of ideas and answers.......Good Luck
Old 04-05-2007, 10:30 PM
jodrayt's Avatar
jodrayt
jodrayt is offline
1996 Ford F150 V 6, Just Had It Tuned Up Because I Drove It Cross Country Last Summer, Its Got A Lot Of Miles On It, Over 190k, The Check Engine Light Has Been On For A While, Went Off For A Bit When I Changed My O2 Sensors, But It Came Back On Like A Week Later. Also Changed The Motor Mounts, And Had A New Tranny Put In Less Than 5k Miles Ago. The Truck Shakes Like Crazy When I Am Sitting At A Red Light Or A Stop Sign Ect, When Its Moving Its Fine Just When I Am Sitting Still Goin Nowere. As Long As I Give It A Little Gas And Keep The Rpm's Up It Doesnt Shake As Bad, But Its Gettin Terrible Gas Mileage And Need To Fix It With These Friggin Gas Prices.
Thanks
Old 04-06-2007, 12:23 AM
unixadm's Avatar
unixadm
unixadm is offline
A flashing MIL may indicate a misfire. I know on my 2003 Ford Crown Vic when I had a bad coil pack, the MIL was flashing which is a BAD thing. The next thing to follow is clogged cats or cat depending on the vehicle.
Since you say it's idling rough, that could be a sure sign of a misfire. When you say tune-up, was it cap/rotor, wires, and new plugs? Did it run bad before the tune-up? I'd get the codes scanned. Hopefully it's nothing serious, but it could be a weak cylinder, clogged cat, bad injector, bad plug wires, weak coil, etc.
Old 07-20-2007, 08:39 PM
Caleb1's Avatar
Caleb1
Caleb1 is offline
Motor mounts bad maybe?
Old 07-20-2007, 09:48 PM
quicklook2's Avatar
quicklook2
quicklook2 is offline
you need to read the codes.
Old 07-20-2007, 11:16 PM
Bruce R Leech's Avatar
Bruce R Leech
Bruce R Leech is offline
get the codes and I would check the EGR among other things. what all was included in the tune up?
Old 07-20-2007, 11:47 PM
lv2race's Avatar
lv2race
lv2race is offline
Don't buy any parts until you check for codes.
Jack Perez
1999 to 2016 Super Duty
05-26-2017 04:54 AM
Ryno327
1983 - 2012 Ranger & B-Series
03-21-2017 11:33 AM
Metz22
05-07-2016 11:42 PM
KDAVID1
11-03-2014 10:43 AM
tackelberry88
1997 - 2003 F150
06-16-2010 08:58 PM
Quick Reply: Why does my truck shake like crazy when its in idle?
