Why does my truck shake like crazy when its in idle? - Ford Truck Enthusiasts Forums
Old 11-18-2014, 06:14 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
Print Wikipost
Old 04-05-2007, 01:29 AM
jodrayt jodrayt is offline
jodrayt is starting off with a positive reputation.
If i run my truck for a little while and sit in idle it shakes, if i give it gas while im at idle it shakes less, my check engine light is on and when it shakes bad the light blinks then stops blinking and stays solid. Any ideas?? Thanks
Old 04-05-2007, 04:24 AM
92F150Flare 92F150Flare is offline
92F150Flare is gaining momentum as a positive member of FTE.
Welcome to the forum
Need more info.....truck, motor "etc"
Did you just do a tune-up and cross some wires maybe? or hasn't it been tuned-up in a long time? Is it making any odd noises? Describe everything as best you can.
Did the check engine light come on at the time it started shaking or was it on before. Reading the codes will tell you why the light is on and point you in a direction to fix it.
Here is some info on the codes>
http://www.ford-trucks.com/article/i...rocedures.html
Give more info and you'll get a lot of ideas and answers.......Good Luck
Old 04-05-2007, 11:30 PM
1996 Ford F150 V 6, Just Had It Tuned Up Because I Drove It Cross Country Last Summer, Its Got A Lot Of Miles On It, Over 190k, The Check Engine Light Has Been On For A While, Went Off For A Bit When I Changed My O2 Sensors, But It Came Back On Like A Week Later. Also Changed The Motor Mounts, And Had A New Tranny Put In Less Than 5k Miles Ago. The Truck Shakes Like Crazy When I Am Sitting At A Red Light Or A Stop Sign Ect, When Its Moving Its Fine Just When I Am Sitting Still Goin Nowere. As Long As I Give It A Little Gas And Keep The Rpm's Up It Doesnt Shake As Bad, But Its Gettin Terrible Gas Mileage And Need To Fix It With These Friggin Gas Prices.
Thanks
Old 04-06-2007, 01:23 AM
unixadm unixadm is offline
unixadm is starting off with a positive reputation.
A flashing MIL may indicate a misfire. I know on my 2003 Ford Crown Vic when I had a bad coil pack, the MIL was flashing which is a BAD thing. The next thing to follow is clogged cats or cat depending on the vehicle.
Since you say it's idling rough, that could be a sure sign of a misfire. When you say tune-up, was it cap/rotor, wires, and new plugs? Did it run bad before the tune-up? I'd get the codes scanned. Hopefully it's nothing serious, but it could be a weak cylinder, clogged cat, bad injector, bad plug wires, weak coil, etc.
Old 07-20-2007, 09:39 PM
Caleb1 Caleb1 is offline
Caleb1 has a brilliant futureCaleb1 has a brilliant futureCaleb1 has a brilliant futureCaleb1 has a brilliant futureCaleb1 has a brilliant futureCaleb1 has a brilliant futureCaleb1 has a brilliant futureCaleb1 has a brilliant futureCaleb1 has a brilliant futureCaleb1 has a brilliant futureCaleb1 has a brilliant future
Motor mounts bad maybe?
Old 07-20-2007, 10:48 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
you need to read the codes.
Old 07-21-2007, 12:16 AM
Bruce R Leech Bruce R Leech is offline
Bruce R Leech is starting off with a positive reputation.
get the codes and I would check the EGR among other things. what all was included in the tune up?
Old 07-21-2007, 12:47 AM
lv2race's Avatar
lv2race lv2race is offline
lv2race is gaining momentum as a positive member of FTE.lv2race is gaining momentum as a positive member of FTE.
Don't buy any parts until you check for codes.
SES light, low power, shakes...Help Metz22 1999 - 2003 7.3L Power Stroke Diesel 12 05-08-2016 12:42 AM
High Idle Shake KDAVID1 6.0L Power Stroke Diesel 7 11-03-2014 11:43 AM
does your truck seat shake when at idle? choate 1987 - 1996 F150 & Larger F-Series Trucks 9 08-11-2014 04:56 PM
Shaking on acceleration alabamawolverine 1997 - 2003 F150 1 07-21-2014 10:00 AM
Shake At Idle frosty38506 1999 - 2003 7.3L Power Stroke Diesel 12 12-18-2013 06:16 PM
Tags
2007, 54, dose, f150, ford, idle, idling, im, shake, sitting, start, still, stopped, truck, tuck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
