You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
My ac has started shutting off intermittently. I feel it surge at highway speeds and the output air starts getting warmer. I can turn the ac OFF, wait a few minutes, cut it ON and cold air returns. The clutch is not engaged when it quits. Also, using an off the shelf guage the freon pressure is at "alert".
Do I have a pressure switch problem? Is the switch replaceable without losing freon and needing recharged? Any help is appreciated.
You'd get more answers in the 1997 - 2003 F150 forum Baileybones however it sounds like it might be low on freon. Also if memory serves me correctly you have to depressurize the system to replace the pressure switch.
I had an ElCamino doing that and it was the engine fan clutch.......slipping and causing the hightemp/pressure switch to cut in and out.
Wiz is right....low freon will do it too
Good Luck
__________________
`92 F150 Flareside - IRIS MET/Gray
5.0, AOD, 355 gears, dual glasspacks no cats, K&N drop in filter, MSD Blaster Coil, Cap and Rotor, Ford Racing 9mm wires - Blue
It's not pink......it's IRIS.
