codes
codes
O.K. I know this is supposed to be an engine forum but for those of you who have ever wondered about spring codes here is some info that was imparrted to me by a very knowledgeable person.
There is a two-character spring code on the vehicle certification sticker on the lower doorpost behind the driver's door. The first character is the front spring code, and the second character is the rear spring code. A common spring code for a CrewCab 4x4 would be VB. The V means 5,200 pounds front springs, and the B usually means the rear springs on an F-350 SRW. However, some F-250s also have code B rear springs.
Any pickup can have any available front spring code - depending on options, and it doesn't matter whether F-250, F-350 SRW or F-350 DRW. Here are the spring codes for the front leaf springs on '99 thru '04 PSD 4x4 pickups:
T = 4,400 pounds @ground
U = 4,800
V = 5,200
W = 5,600 (rare on a pickup)
X = 6,000 (only with snow-plow pkg on a pickup)
Rear spring codes:
A = F-250 & Excursion (6,084 pounds @ground)
B = F-350 SRW (6,830 pounds @ground)
C = F-350 DRW (8,250 pounds @ground)
If you already have code B rear springs, then you already have the same rear springs that are on F-350 SRWs.
If you have Code U or V front springs, then you might like the code X front springs. In addition to giving you a little more weight capacity on the front end, they will give you a one to two inch lift of the front end.
If you wanted to really beef up the springs on your F-250, then put the code X front springs and the code C rear springs on it (they should bolt on). But be warmed it will then ride "like a truck". [img]cool.gif[/img]
BTW, NEVER change leaf springs without replacing all the U bolts with brand new U bolts.
Now with all that being said the only real difference between those of us that have a B rear spring in a F250 and a SRW F350 is that stupid 4" block.
U = 4,800
V = 5,200
Rear spring codes:
Stewart_H
10-24-2017 11:57 AM
EndorphinJunky
Ford Truck Parts for Sale
424
03-23-2015 05:15 PM
ATS Junior
Vendor Specials, Discounts, Product Announcements & Group Buys
04-21-2014 10:18 AM
LeoJr
11-26-2012 01:15 PM
bigwhitetruck01
05-27-2012 03:45 PM
