2002 F-150 FX4 Brake Rotor Question
I have a 2002 f-150 fx4 4wd. Im replacing all 4 rotors, the parts house system pulls up two different rotors, a 12 and 14 rear solid rotor larger diameter, and only a 12 vented front rotor. I dont have a 14 option on the front. I was assuming that all my lug studs were a 14 as it's a 4wd. Is my assumption wrong or does this truck come with m12 lug studs all around?
Also, does anybody have a recommendation as to which brand rotors seem to work out well with the fords?
I have used powerslot/autospecialities rotors for years. I really want to try a set of DBA rotor, though.
From what I saw, the 2wd has the 12mm lugs.
VENDOR BAER BRAKES (B71)
PART NUMBER 54090020
APPLICATION BRAKE ROTORS, 2002, FORD, PICK UP FULL SIZE, BAER BRAKES, BRAKE ROTORS DRILLED/SLOTTED, F150, ALL ENGINES, 4 WHEEL DRIVE, REAR, ALL QUESTION 3, ALL QUESTION 4
> CROSS DRILLED, SLOTTED ROTATIONAL ROTORS SOLD IN PAIRS WITH A LEFT AND RIGHT ROTOR.
RETAIL PRICE 364.35
RETAIL PRICE 364.35
VENDOR BREMBO (B39)
PART NUMBER 37015
APPLICATION BRAKE ROTORS, 2002, FORD, PICK UP FULL SIZE, BREMBO, CROSS DRILLED BRAKE ROTORS, F150, ALL ENGINES, 4 WHEEL DRIVE, 5 X 14MM LUGS, FRONT, ALL QUESTION 4
> PART NUMBER CONTAINS BOTH LEFT AND RIGHT SIDE ROTORS
RETAIL PRICE 375.57
PART NUMBER 37015
RETAIL PRICE 375.57
jim milewski
09-07-2017 02:17 PM
