Front axle shaft u-joint
OK last night I got new Warn manual hubs and replaced them, the passenger side was real bad. I do not think anyone ever did maintenance on them. I replaced them but noticed that the passenger side axle shaft u-joint has a lot of play in it. I can move the axle shaft up down and forward and back quite a bit. The u-joint looks to have caps over the ends and I did not try to pry one off. Is it possible to just replace the u-joint or do I need to replace the shaft? The rest is in good condition, it's just the u-joint that is toast.
on
You have to remove the side axle to change the U-joints. It's not a hard job but does require a special socket to remove the hub bearing retainer nuts. Basically you have to remove the hub lock mechanism, remove the bearing retainer nuts and remove the hub/rotor assembly, remove the inner hub/bearing race, and then pull the side axle assembly out. First time doing this plan on a couple hours per side, the inner hub plate will require some prying to free it from the spindle.
mattdmason
13
12-31-2009 02:51 PM
Taasman
04-24-2004 04:43 PM
Kenny
12-15-2003 06:43 PM
