knocking after oil change again
#61
Originally Posted by 04 FX4 Lineman
Since you are such a rocket scientist suppose you tell me how you fill and oil filter that lays on it's sidethen get it in a place barely big enough for your hand without loosing any?????
#62
You are not correct sir do some more research!!
your best bet to help eliminate the noise is:
1. get engine to operating temp
2. drain oil ASAP
3. remove filter, fill new filter 1/2 way and install
4. replace drain plug and fill motor with remaining 6 1/2 quarts oil
5. prime motor if that is your thing (I personally don't)
6. start motor and let idle for a minute or so.
7. if noise persists, go to dealer and kiss some serious @ss. if your lucky they'll do something. if this noise is only exhibited during the first startup after an oil change, they'll probably tell you to pack sand.
for those who have had chevy's, that blue puff is normal. for some reason their Engineers designed a 1/2 quart oil consumption into their engines. I can't think of any good reason for this, but almost every 5.3 and 5.7 V-8 they make does this. haven't heard if the 6.0 does it. you see, Ford isn't the only one with weirdness
#63
Originally Posted by tylus
they were talking about the plugs blowing out. not the carbon build up. no one is disputing that this carbon build up is a problem right now. What was discussed, was that the "old" 5.4 had a nasty habit of blowing out plugs. The new 5.4 3V does not have this problem.
thought so....
#64
With 473K trouble free miles with a pre-oiler installed old school FE designed 414 that has silent cold or oil changed starts I believe what they call new isn't necessarily good or better.
For years i've always wondered who buys this new plastic crap?
Sorry stuck with steel not plastic.
Might as well get into the flame wars.
#65
Don't know what all the noise is about.... been changing oil for over 30 years, that's just normal dry start-up clatter. Takes a couple of seconds for the oil to pump up to the upper cylinders, no big deal. Just half-fill your filter before installing and let engine idle upon starting. Watch your oil pressure gauge, it'll pop right up.
#66
#67
THAT is NOT start up clatter, unless he's just spazzing out.
#68
#69
Originally Posted by rsylvstr
it's because of his original post....I've heard dry start up clatter on some vehicles, but he states "violent engine knocking sound for about 2 or 3 seconds"
#70
#71
You said 2 or 3 seconds that is normal. If it persists for an extended period of time then you have a problem. Since it's 2 to 3 seconds, forget about it!
Beeford, your engine is totally different than the ones you had in the past. You must not be reading all the posts. The oiling system on this is a little different than your old non OH cam engines. The 5.4 3v has OH cams with variable valve timing.
You have two things working against you, one a dry oil filter, two the oil drained back after the oil filter removal.
You came here looking for answers we provided you with them. If you consider this all nonsense then go to your dealer and get his view. Lets just put an end to this.
#72
#73
Originally Posted by baitmaster
Never understood why manufacturers couldnt mount an oil filter right side up so you could fill it with oil before crankup. I have a remote filter setup on my '72, and this works fine. Why wait for the oil pump to fill the filter before getting it up to the lifters.
#74
on
Originally Posted by 4DOORSR
Thus the reason some of us are mechanics and some of us are not...
Originally Posted by TYLUS
I'm 6'3", 270lb and have ginormous hands. I have no problems getting to that filter. Nor have I ever spilled oil on my truck. I just fill the filter 1/2 full, and get it screwed into place quickly.
Thanks to both 4DOORSR and TYLUS.
#75
Well, he COULD have a problem, but without actually hearing it I couldn't tell for sure. The TSB is for clatter on cold start-ups, he states it only does it after an oil change, and quiets down after 2-3 seconds, which leads me to believe it's only dry start-up clatter. As for being " violent", well, everybody's got their own definition of what that is. If it really bothers him, it wouldn't hurt to bring it in, but how would they duplicate the noise without soaking him for an oil change?
could be something getting ready to go and the reason it happens after an oil change is not enough oil (duh) ...wonder what it sounds like when he revs it? WOT? etc.
