I need a 1995 EEC 4 module but am running into a problem. I am using this to swap to mass air from a 1991 speed density. I need a 1995 5.8 E4OD mass air module and there are a bunch listed. Does anyone know how to decode the part numer or can you suggest a part number, stock or aftermarket. I have run into a problem with most local junk yards because they try to keep parts together with engine, so I am guessing I may have to buy new. Thanks for help.
motorsport kit is 750.00 and comes with harness, 30 injectors, hoses I don't really need all that but I will call to see if they can recommend which eec 4. I just need the module.
I need the part number for the California emission eec4, 5.8 E4OD 4X4 with mass air. 1995 model. The info I have says processor number BIO0 last digit is zero.
