Look at the codes I got my Edge when I went back stock..
1)P2107
2)U0300
3)P0600
4)P1000
5)P2100
6)P2105
Anyone ever see any of these codes, and can I get them off my PCM?
1)P2107
2)U0300
3)P0600
4)P1000
5)P2100
6)P2105
thats only 1/3 the amount my edge was causing....all sorts of codes were flying all the time....i sent it back...scared me.....the one time i had 18 different codes...i got all of those a couple times....transmission codes, fuel injector codes, throttle stuck codes, engin safe mode codes....it was crazy....
but, now i hear that edge put out a new beta version so i'd suggest going and downloadign that and seeing what happens...
I had some problems and they are working with me to get them reslved. They actually just put out a update that fixed most of my problems. They are still working on something for me so there should be another update soon. Give them a call and they will get your files and fix your problem.
P2107 = TAC module processor error
P0600 = Serial comm link malfunction
P1000 = OBD systems readiness test not complete
P2100 - TAC motor circuit/open
P2105 = TAC system forced engine shutdown
That's probably the computer not knowing what to do with the electronic throttle when the mapping is not altered by the Edge.....
