51 F6 Radiator support Alignment
51 F6 Radiator support Alignment? There looks to be two places to align the radiator support. Is one for a flathead 8 and the other for a flathead 6 which is a longer engine? I put my front clip in place, but there is no room for the radiator. It looks like I have to move the support forward and use the two front holes in the crossmember for the 226 engine. Is this correct. I am going to move the support tomorrow morning at 10.00 am. My friend is suppose to come over and help me lift the clip back off.
Thanks Kevin
Thanks Kevin
You shouldn't have to remove the clip again in order to move the radiator support. Just remove all of the bolts from boths sides of the clip and on the bottom crossmember, and slide the radiator support to the correct position. Then reattach all bolts in the new area. You'll also have to move the fender braces.
Ilya
Ilya
on
Ilya
Ilya
pholmes350
06-21-2016 02:41 PM
winginit
09-28-2015 05:55 AM
Chiefmech1
02-15-2015 02:53 PM
