Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
  #1 (permalink)
Old 04-02-2007, 06:16 PM
racingtom racingtom is offline
Garage is empty, add now
racingtom is starting off with a positive reputation.
Question HELP P1316 code & Runs Rough??
On sat. morning I drove appx. 1/2 mi. parked, came out 5 min. later and started my 2001 F350 SD Diesel W/75,000 mi. and it was running rough and the SES light was on. I changed fuel filt. in the fall and maintain it well.
Pulled the code with my OTC Genisys and came up with P1316 Ignition Diagnostic Monitor Codes Detected.
My Alldata dosen't go to 2001 and I have no other info for this truck. I'm thinking I've got a injector gone bad.
Any one have any exp. with this that can guide me??
TIA
Tommy
  #2 (permalink)
Old 04-02-2007, 06:49 PM
Pocket's Avatar
Pocket Pocket is offline
Pocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud of
P1316 is a generic IDM code. It means that you have more codes stored inside the IDM itself. The way to retrieve them is to run an injector buzz test.
Since I've never used the Genisys, I have no idea if it's capable of that. Quite a few PSD owners as well as myself use Autoenginuity, which can run a buzz tests and pull IDM codes in a few seconds.
If you can't pull the IDM codes at the moment, your best best is to first check the UVC harnesses. They are located in the middle of each valve cover and each face the valley of the engine. You'll either have chaffed wires from a failed harness, or the clip underneath the valve cover popped off. For that you'll have to take the valve covers off and reconnect. They come off surprisingly easy.
Hope this helps.
__________________
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the Colorado diesel community.
  #3 (permalink)
Old 04-02-2007, 07:07 PM
Thanks Pocket I'll ck if I can do a buzz test tommorrow.
Not to sound stupid but what is the IDM ??
  #4 (permalink)
Old 04-03-2007, 12:22 AM
wlihntr's Avatar
wlihntr wlihntr is offline
wlihntr has a good reputation on FTE.wlihntr has a good reputation on FTE.
Quote:
Hope this helps.
yep ...most of the time thats it...
__________________
2001 Powerstroke, CC,SB,Lariat,Auto,4X4
Mods. in Gallery
2007 Lincoln MKZ awd
http://www.ford-trucks.com/user_gall...oid=65664&.jpg
its good to have an open mind...but not so open that your brains fall out
  #5 (permalink)
Old 04-03-2007, 06:25 PM
Well I started my truck this morning for my drive to work (appx 8 mi. drive) and it was running fine with no SES light, at arround 6 mi. here it goes again missfiring and SES on.
So after work I decided to pull the valve cover's and of course the second one I pulled
the connector was backed off, while I had the both cover's off I secured both harnesses inside the cover's. Only took about 2 hrs. . Started good and road tested, runs great.
Thanks for the help guy's.
Tommy
  #6 (permalink)
Old 04-03-2007, 06:33 PM
Pocket's Avatar
Glad you got it back up and running right.
__________________
Curtis
2002 F-250 PSD
  #7 (permalink)
Old 04-03-2007, 06:44 PM
Thank's Pocket.
Just for reference I'll check if the Genisys can do a buzz test.
  #8 (permalink)
Old 04-04-2007, 05:14 PM
Well I checked today and in the "Self Diagnostics" menu with a OTC Genisys here are the test's.
KOEO Injector Buzz Test
KOEO Output State Test
KOER Self Test
KOER Glow Plug Self Test
KOER Cylinder Contribute Test
KOER Switch Self Test
Ran all the test's and all is good now.
Tommy
  #9 (permalink)
Old 04-04-2007, 05:39 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
I think Pocket rates some rep points for that (click the scales on the right upper side of his post).
Great going!
__________________
- art k. - Moderator for the Superduty, V10, 6.2L and FE forums
'13 Taurus SHO 3.5L Ecoboost w/Perf Pkg
'01 F250SD SC SB XLT V10 4x4 Volant CAI Hedman headers 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see. ®
  #10 (permalink)
Old 04-04-2007, 05:50 PM
Wink
Quote:
Great going!
Done
Tommy
Tags
2000, 2001, codes, detected, diagnostic, duty, f250, ford, fordp1316, iddle, ignition, monitor, p1316, rough, ses, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
