Washington Chapter Washington Chapter
Join Chapter, Leader: Yahiko
Hey all
Old 04-11-2007, 10:40 AM
lud04X's Avatar
lud04X
lud04X is offline
Hey all
Just found out about this section of the board. I just bought a 1978 F150 ext cab 4wd that I plan on fixing up, making it look nice, and using to pull a 17' 1964 Airstream Bambi II trailer that's been in my family for a long time.
The great part is everything works and it was maintained very well in my opinion and doesn't drop anything. The bad is the body. Some surface rust in some spots and one hole at the driver's side rear corner. I'm not sure whether I should fix the bed or get a new one.
Anyway I'd be interested in meeting up with any of you whenever. I moved out to WA state from IL about a year ago so I don't know a lot of people. I also drive a 2004 Wrangler that's built for offroading and ride a motorcycle as well if people are into stuff like that.
Old 04-11-2007, 11:13 AM
RexB's Avatar
RexB
RexB is offline
Welcome Aboard lud04X, good to virtually see you!
Good truck, I have a '78 myself (with a '79 front clip), the 400M with a C6 is a strong puller. If you have the same motor it will do well. This towed many a load of lumber and a big U-haul from Florida.
Your Airstream is just 2,000lbs dry (it's a 17-footer?), so no problemo.
We're having a get-together (G2G) June 22-24th here on Whidbey Island. You're 200 miles away by crow, if you want to take a fandamtastic bike ride up here then.
(Maps are in G2G thread sticky)
Old 04-11-2007, 01:08 PM
nubeee1's Avatar
nubeee1
nubeee1 is offline
Hey lud04x.....Welcome, You are going to join WA Chapter, Right?
Ford Trucks best damn puller in the world!!!
Old 04-11-2007, 04:39 PM
brentleedragon's Avatar
brentleedragon
brentleedragon is offline
hey lud04x! i believe i saw you on the 73-79 forum and shot you over in this direction...promise you wont be disappointed!
tony_corbin
New Member Introductions
03-04-2014 07:54 AM
Sycostang67
09-12-2011 03:58 PM
andym
General Automotive Discussion
38
08-11-2005 12:43 PM
53wa2fl
07-17-2005 07:07 PM
77300i6
43
04-09-2005 03:52 PM
Quick Reply: Hey all
