351W eating cam and distributor gear?
I replaced the timing set, camshaft, and complete distributor--It ran for two weeks, and totally destroyed the camshaft gear and the distributor gear. I am afraid that the camshaft may be "walking" forward, but do not see a way to keep it in place. What do I do?
(1) Drill a .030" hole in the lifter/oil galley plug behind the distributor. This will allow additional lubrication on the distributor and cam gears. This will not lower oil pressure enough to hurt the engine.
(2) Ford oil pump mounting brackets have elongated holes. Due to this, the distributor shaft and oil pump shaft should be aligned so that the distributor turns freely before tightening the mounting bracket bolts. Failure to do this will cause a binding situation, thus damaging the gear.
(3) Stock Ford hex oil pump drive shafts are know to vary in length which could cause a bottoming or binding situation.
(4) Brass distributor gears can be used to avoid damaging the cam gear. Brass gears are softer and can wear out quicker than the cast gear, but will not cause damage to the cam gear. If using a brass gear, check it occasionally for wear
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
FTE Sponsor
If you had listed the year and/or the dizzy ID number (on the base below the cap), I could have told you what the correct dizzy is, and the correct gear and number of teeth it has.
There are TWO different oil pump shafts used on a 351W.
351W oil pump shafts: C9OZ-6A618-A 1969/1978 OR D9AZ-6A618-A 1979/.
1. How do I know if I have the correct gear on the distributor?
2. How about the correct oil pump shaft?
3. With my cam installed like the picture below, there is a lot of "end play". In fact, so much so that the fuel pump eccentric actually rubbed against the timing cover and left shavings in the cover.
4. I did install a high volume oil pump, because I had virtually zero oil pressure when the engine was warmed up and stopped at an intersection or red light. Should I remove and replace it? What about the oil pressure?
5. I have no idea what year model the engine is, how do I tell?
6. I'm fairly sure I have the correct distributor; the oil pump shaft is definitely larger in diameter than a 302.
Here are the numbers from the distributor:
D0AF-12131-A
I gotta get this thing going!
Thanks,
Vern
D0AF-12131-A
Thanks,
Vern
Just to jump in with one last piece of information, my machine shop guru who I grew up with and have known for over 30 years specializes in NASCAR and short track racing engines (No, I don't do either)> But, I have asked him numerous times over the years about the advantages and disadvantages of hi-volume oil pumps. His constant answer over the years makes alot of sense:
1. Hi-volume oil pumps require high volumes of oil...therefore larger that stock oil pan is always required.
2. If stock oil pan, use stock flow pump...period.
bruno2
10-17-2015 11:47 PM
bumpDan71
08-03-2015 02:20 PM
fstbck1970
03-06-2014 07:07 AM
jcrawford@casco.net
03-30-2004 09:07 PM
