Sway bar good or bad
Originally Posted by Fomoko1
It maybe hard to find a swaybar the right width, most of the newer trucks are wider although something like a Ranger, ect may work.
Originally Posted by mechmagcn
I used the rear bar from a 88 BroncoII on my 53, almost a direct bolt-in.
I want to try the front too. From the measurements I have, it should be close.
Does anyone know of a site or other method of I.D.'ing a sway bar? I have an 1 1/8" bar on the back of my truck that I'd like to i.d. as I need new links and bushings,and I'd just like to know what it is.. I talked to a guy at No Limit who said there is no way of knowing w/o something being stamped on the bar. I may take a foto of it tonite, since my bed is off, and see if anyone recognizes it.
Brian, I will have to wait till I take my bed back off to get pics. The "almost" part was to drill out 2 holes to a larger size, the holes were already in the frame.
Did you look at the front one before you removed the front axle for the clip?
Originally Posted by Brian_B
Not a problem at all. I can drill holes! I thought you meant re-shaping or making mounts or something odd. Did the mounts fit the stock rear axle ok? Or is yours a 9" (or other)?
As for the front, the PO had already removed the front axle and cobbled up a Volare install, that's the reason for the frame clip.
Here's the best pic I could get with the bed still in place.
73FordF100
05-09-2010 12:36 PM
