transmission number decode - Ford Truck Enthusiasts Forums
Old 03-31-2007, 06:18 PM
mattsf-100 mattsf-100 is offline
mattsf-100 is starting off with a positive reputation.
Hey guys I need this transmission number decoded.
C8 AR 7006-C
This is for a 1964 f-100. With a 223 inline six.
Thanks
Matt
Old 03-31-2007, 11:23 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
C8AR 7006-C This is for a 1964 f-100. With a 223 inline six. Thanks
Matt
It may be in a 1964 F100, but it's from a 1968 Ford passenger car.
Doesn't matter, all the internal parts are the same for this 1968 all syncro 3.03 Ford 3 speed transmission as they are for a 1964.
Old 04-01-2007, 12:14 AM
Thumbs up I found more #s what do these mean
Thanks for the information.
I found some more #s on the transmission.
RF 65AR 7050
what do these mean.
Just wanted to make sure that this tranny would work in my truck. Any idea what size clutch and stuff to make it fit my 223?
Thanks
Matt
Old 04-01-2007, 12:25 AM
RF 65AR 7050 Should read C5AR, it's the engineering number for the input shaft bearing retainer at the front of the tranny.
what do these mean.
Thanks
Matt
10" clutch, 6 springs on disc.
B3TZ-7561-A .. Throwout Bearing Collar
C0TZ-7580-A .. Throwout Bearing
70-7600-B .. Pilot Bearing
All parts are available from auto parts stores.
Decoding Warranty plate and serial number 1960 F-100 Custom Cab Pacecar1986 1957 - 1960 F100 & Larger F-Series Trucks 5 01-02-2017 05:56 PM
decode wanta65 1961 - 1966 F-100 & Larger F-Series Trucks 1 11-11-2015 06:34 PM
Decoding warranty plate and serial number 1960 F-100 Custom Cab Pacecar1986 1957 - 1960 F100 & Larger F-Series Trucks 2 07-17-2014 08:18 PM
FE Block Numbers 66BlueOval FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 9 01-03-2013 07:36 AM
1956 f100 VIN Plate redf100pu 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 02-28-2003 11:15 AM
Tags
187006c, 7006, 7050, 7580, bearing, c0tz, c5ar, c8ar, c8ar7006, casting, ford, numbers, retainer, transmission, transmissions
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
