Welding Tailgate to Bed Pros and Cons
sound kinda like a weard question. it would be find if you never want haul any thing heavier than you can lift over the side. if you want to build a show truck and you did a good job of welding it and blending it in it would make for a rear smooth back end. it would be unique if nothing else, i mean some people weld there doors shut.
Tailgate
Why would you want to screw-up such a beautiful truck? If it is making a unwanted noise, find the area or part doing it/fix it. It could be a cracked weld, chains or the tailgate. If it's the tailgate, take it off and use a web like many modern pickups. Present the problem on FTE and someone will suggest a better solution for you. It definately would effect resale values. Have a great day,chuck
I'm sure you're getting tired of all the advice by now, but here's my $.02. I'm sure it would look cool to completely smooth it out. BUT..there are so many cool ways to clean up the back, hide the latches, hinges, smooth covers, etc. There must be a dozen different ways and hundreds more you could invent that would still leave it functional. It IS a truck after all....
on
I'm not building my truck for show but even if I were I'd want a functioning tailgate. Without it the bed may as well be a trunk. If you feel that you have to weld it shut, how about a couple of very small tacks which could be easily broken if the next owner chooses to use the tailgate as intended? We've heard a lot of unflattering stories on this forum about previous owners. Mine welded the seat frame to the floor. Don't be in one of those stories...
Con: You can't Tailgate at the big game!
If you have rattles, get the rubber wedge shaped things that are supposed to go at the upper edge of the tailgate. I had a loose chain clamp. The rubber wedges were laying on my shop bench for years. On a chacne I out them in and it tighened the whole thing up and now the clamps are tight, the tailgate id tight, and the backend of the bed sides are firmer.
tabascom16
05-28-2015 09:09 PM
superman64011
22
07-12-2010 03:10 PM
CHUCKS65PHUGLY
06-23-2006 09:06 PM
