Conversion / Swap: C6 to E4OD questions - Ford Truck Enthusiasts Forums
Old 03-29-2007, 04:18 PM
paperstreet paperstreet is offline
paperstreet is starting off with a positive reputation.
Hello, all. Thanks for reading.
I'm looking to swap my C6 with a Gear Vendors OD for an E4OD. Looking for a 97 or newer DIESEL E4OD from the junkyard, and looking at either Compushift or Baumann Electronics for the brains of the operation, but I was hoping to ask around to see what other surprises are out there waiting for me on this project.
This is my FIRST Ford Truck. It's a 1987 F-250, 6.9 Litre Diesel, Banks Turbo, Gear Vendors Over/Under drive.
I'm looking to swap because I want a lock-up converter, and the Gear Vendors unit is acting up, dropping out of OD at highway speed or whenever I start to get on it. Downhill coasting, it'll chatter like all hell, hopping in and out of OD. In either case, I'll be happier with a real OD trans and lock-up. Anyone looking to swap should email me.
I have a few questions:
Do I need a different / new flywheel? Flex plate?
Is there anyone out there besides Baumann Engineering and Compushift that makes a brain for this trans?
Driveshaft shortened? Yoke ID / OD?
Rear end ratio / ring gear need to change?
I don't tow much, it's mostly a motorcycle hauler, so is there a taller rear gear I can look into? Dana?
Thanks in advance for all your replies!
Frank
1987 Mercedes 190D Turbo on vegetable oil
1987 Ford F-250 Banks Turbo on Biodiesel
1986 Honda VFR700FII on crack
AOD rebuild PlumCrazy7 1987 - 1996 F150 & Larger F-Series Trucks 76 04-15-2015 10:14 PM
E4OD Operation danlee Clutch, Transmission, Differential, Axle & Transfer Case 168 11-01-2014 03:18 PM
Banks Transcommand or The Baumannator Controller gtsom6 1994.5 - 1997 7.3L Power Stroke Diesel 44 08-22-2007 07:56 PM
Which is better NP208F or BW-1356 TLindquist Clutch, Transmission, Differential, Axle & Transfer Case 2 11-10-2002 01:07 AM
baumann or banks trans command, any preference?? capt scott Clutch, Transmission, Differential, Axle & Transfer Case 1 05-19-2002 03:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
