1967 F100 rare option?
A friend has his fathers 1967 F100 with with a 352 Cleveland and 3 speed manual on the column with overdrive in second and third via a switch/control on the dash. His father bought the truck new. Was this a rare option with the 352 and 3 speed manual with overdrive?
There is no switch on the dash. To the left of the steering column, under the dash mounted to a bracket, is the O/D cable that has to be pulled out to activate O/D, but only when the truck is not moving! Otherwise...
Behind the accelerator pedal is the O/D kickdown switch, mounted on the firewall behind the air cleaner is the O/D relay. The O/D unit itself bolts to the back of the trans, has a solenoid and governor mounted on it.
I bought a new 1965 F100 352 with T-85N O/D. This was not a rare option, but considering the survival rate of these trucks, it's somewhat rare to find one today with O/D.
Replacement parts can be a real b!tch to find as the T-85 was also installed in 1939/56 Packard, 1942/51 Lincoln, 1955/56 Nash/Hudson, 1956 Studebaker Golden Hawk & 1/2 ton pickups and other make vehicles.
Every one of these vehcles is collectable (especially the Packard's), so new replacement parts are mostly long gone, expensive if found.
No such thing as a 352 Cleveland. 352 is an FE engine, Ford never referred to FE engines as Clevelands.
The only Cleveland so designated is the 351C, installed in 1970/74 Ford/Merc Passenger Cars only.
I've only seen a few bumpsides with OD. I had the tranny from a 68 but plans to use it fell through. Lots of people have eliminated all the throttle kickdown and just put a switch to control the over drive. Then you can basically operate it like a 2 speed. You can even bypass the low speed lockout so you have OD in low gear making a six speed but it's kinda pointless.
Ford used the R-11 overdrive in the pickups and it is the stoutest unit Borg Warner made. I'm not sure if all the cars with T85 trannys had the R-11, seems like most used the R-10 but I could be wrong.
Depending on the year, applications, R9, R11's were used in cars. But very few Ford cars came with T-85's. Most used Warner T-86 O/D's as did other automakers.
What preceded and was used thru 1948 on Ford/Merc cars? Columbia 2 speed rear end. First installed in the 1935 Auburn, Columbia was owned by E. L. Cord, who also owned (at one time) Lycoming, Auburn, Cord & Duesenberg.
Regardless of how the O/D is activated, the scarcity of parts is the major problem. The O/D relay used in 1965/71 F100's is non existant.
The 6V relay used on myriad vehicles, has been reproduced by Studebakers West of Redwood City CA / AFAIK, no one repro's any of the 12V relays.
traman
16
05-06-2016 04:46 PM
65 Ford F-100
19
09-24-2014 01:15 PM
Mikulh
12-15-2011 10:53 AM
