firestone air pump for air bags
I just bought the air pump and 1/2 gal tank for my air bags. I was wondering where all of you mounted your pump. It states it needs to be in a moisture free spot. I was thinking in the cab behind the passenger back seat. Sure it would be loud when I make a adjustment but it would stay dry there. I would mount the 1/2 gallon tank somewhere under the truck and just pipe the line through the floor or something. I checked under the hook but could find a place. Any ideas or has someone done this?
sweet03cobra
Here is a link to a recent thread with mounting pictures etc... mounted under the truck at frame rail in a battery box.
http://www.ford-trucks.com/forums/59...-mounting.html
There is also a write up article on this over at TDS.
Hope this helps.
Hope this helps.
I mounted a Viair 450c behind the rear seat on the left in place of the factory joke...I mean jack other than the noise seams like a good place.I modified a black rubber strap to hold it down like the jack was held down on the bracket. A 5 gal tank is mounted on the frame rail on the inside.
ngng
6.7L Power Stroke Diesel
16
04-10-2019 01:59 PM
