Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > Washington Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Washington Chapter Washington Chapter
Join Chapter, Leader: Snowbunny
  #1 (permalink)
Old 03-27-2007, 08:50 PM
MARTYSTOWRIG's Avatar
MARTYSTOWRIG MARTYSTOWRIG is offline
Garage is empty, add now
MARTYSTOWRIG is gaining momentum as a positive member of FTE.MARTYSTOWRIG is gaining momentum as a positive member of FTE.
I need brakes
I need to put rotors and pads for my truck. I have looked at ART and they have a nice set up(330.00). I also checked NAPA end theirs are ok(285.00) I also looked at Autozone(200.00)
Does anyone have a real opinion on this? I know the autozone stuff is not great quality and the NAPA is much better, My question : is it worth the additional cost of the cryo's from ART? A buddy of mine says he couldnt tell a difference in his 2500 Ram diesel.
__________________
Pimpin Gas Piper
99 F250 EX Cab, 4X4,
Sirius Radio,Blackbird GPS/NAV
Kargo Master Pro II Rack
Cobra 75, Lariat trim, BFG A/T T/A
original Crown Society Member
  #2 (permalink)
Old 03-27-2007, 09:19 PM
JR182PILOT JR182PILOT is offline
JR182PILOT is starting off with a positive reputation.
Marty, have you had the rotors turned before? I get mind done at NAPA, I always check to see if I can get them turned at least once. Saves some money.
__________________
J R
Gone, Left, Bye Bye
  #3 (permalink)
Old 03-27-2007, 09:21 PM
have not yanked em off yet. this is my first brake job on this trk. I have a wickid shimmy when breaking. They may be turnable but i do not have the time to get em off and turned in the same day.
__________________
Pimpin Gas Piper
  #4 (permalink)
Old 03-27-2007, 09:29 PM
e9tac's Avatar
e9tac e9tac is offline
e9tac is starting off with a positive reputation.
Drop these guys a line...I ordered mine this evening.
http://www.rotorpros.com/
__________________
95 | Black Lightning #957
  #5 (permalink)
Old 03-27-2007, 09:31 PM
what did they run you?
__________________
Pimpin Gas Piper
  #6 (permalink)
Old 03-27-2007, 09:34 PM
e9tac's Avatar
Different trucks...different prices.
Let's just say for what you get they were VERY inexpensive!
__________________
  #7 (permalink)
Old 03-27-2007, 09:55 PM
Placermike's Avatar
Placermike Placermike is offline
Placermike has a very good reputation on FTE.Placermike has a very good reputation on FTE.Placermike has a very good reputation on FTE.Placermike has a very good reputation on FTE.
Quote:
Pull your wheel and take off you caliper and shoes. Pads are about $20, Calipers are about $40. Some rotors can be turned and some have to be resurfaced. Most of the time just have Napa resurface your rotors...New rotors are pretty cheap through Summit.
Look at wear on everything...Was your caliper piston sticking? Can you see the studs on the pads you took off? Are there well worn grooves in your rotors? All these things will let you know what you really need to replace.
Don't pay someone to do it. It can be done with a few wrenches and a c-clamp.
__________________
"I wear my own kind of hat" (Merle Haggard)
EClampus Vitus Major WM Downie 1849
  #8 (permalink)
Old 03-27-2007, 09:57 PM
brentleedragon's Avatar
brentleedragon brentleedragon is offline
brentleedragon is starting off with a positive reputation.
turn your rotors..if they are warped which tends to happen napa can fix em for a good price
__________________
'79 F-150 Custom Explorer 302 -2wd C6 (condition pending)
-All The Hype That Money Can Buy-
Join The Washington Chapter .... because wherever we go that is where the party is at.
  #9 (permalink)
Old 03-27-2007, 09:59 PM
I have done alot of brake jobs. I just want to get good ones without going overboard. I keep hearing people talk about the cryo rotors and i want to know if they are worth the extra 100.00 bucks I always use napa for my machening. I just do not have the time this week to get them off then to NAPA to get turned and back on. I am out of town sat and sunday. I may take friday off to do it though. Thanks for the info and help though Mike
__________________
Pimpin Gas Piper
  #10 (permalink)
Old 03-27-2007, 10:03 PM
OK GUYS,
Let me rephrase.
I want to know if anyone has an opinion one way or another on spending gobs of cash on rotors?
YES I know not to skimp on brakes but I want to know if all the extra is going to be noticed.
__________________
Pimpin Gas Piper
  #11 (permalink)
Old 03-27-2007, 10:06 PM
e9tac's Avatar
The reason I went with the drilled/slotted rotors is because they reduce heat up to 250 degrees and heat is a major factor for warped rotors and brake fade. So, to answer your question, I think it's worth the money.
My 2cents.
__________________
  #12 (permalink)
Old 03-27-2007, 10:37 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
1969 Ford F-250
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
Get rotors, the factory ones on that truck are thin and tend to warp. Once you turn them, they are now thinner and will warp faster.
I usually get my rotors from Advance Auto (Schucks here), but I haven't had to replace rotors on anything since I got out here. Going to have to soon, though- getting four wheel disks on the 72, and hopefully power front disks on the Galaxie as soon as I can find donor parts.
__________________
Jared
Real trucks have the key on the left
FTE Guidelines
  #13 (permalink)
Old 03-28-2007, 01:49 AM
lostmybeer's Avatar
lostmybeer lostmybeer is offline
Have a nice Beer!!!
lostmybeer has a very good reputation on FTE.lostmybeer has a very good reputation on FTE.lostmybeer has a very good reputation on FTE.lostmybeer has a very good reputation on FTE.
Marty, I've had mine done on my 02. Definately blow the extra $100.00 and get the heavy duty pads. Especially if you are hauling or pulling heavy loads.
  #14 (permalink)
Old 03-28-2007, 08:59 AM
thanks guy's
just needed some insight
__________________
Pimpin Gas Piper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
