Go Back   Ford Truck Enthusiasts Forums > Diesel > 2011 6.7L Ford Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2011 6.7L Ford Diesel Discuss the upcoming Ford Powerstroke 6.7L diesel engine
Is F-150 Still King?
  #16 (permalink)
Old 03-27-2007, 01:52 PM
PowerStrokeHD PowerStrokeHD is offline
PowerStrokeHD has a great reputation on FTE. PowerStrokeHD has a great reputation on FTE. PowerStrokeHD has a great reputation on FTE. PowerStrokeHD has a great reputation on FTE.
Quote:
Originally Posted by biz4two
Yes in the May 2007 issue of FourWheeler it does talk about "IN" house diesels from FORD.
2010
Both the 6.7L V8
and
the 4.4L V6
The 4.4L is a V8 not a V6, and should be in the F-150 for 2009. It could be possible that it also ends up in the Super Duty for 2010 as a entry level diesel.
__________________
'04 F-250 Harley-Davidson 6.0L CC SB
  #17 (permalink)
Old 03-27-2007, 02:02 PM
kw5413's Avatar
kw5413 kw5413 is offline
Texas Proud
kw5413 has a spectacular reputation. kw5413 has a spectacular reputation. kw5413 has a spectacular reputation. kw5413 has a spectacular reputation. kw5413 has a spectacular reputation. kw5413 has a spectacular reputation. kw5413 has a spectacular reputation. kw5413 has a spectacular reputation. kw5413 has a spectacular reputation. kw5413 has a spectacular reputation. kw5413 has a spectacular reputation.
0.00035 %...actually.
__________________
"There is a fine line between fishing... and just standing on the shore looking like an idiot"
  #18 (permalink)
Old 03-27-2007, 02:19 PM
a-rod's Avatar
a-rod a-rod is offline
a-rod is gaining momentum as a positive member of FTE. a-rod is gaining momentum as a positive member of FTE.
So wasnt this 6.4 tested all summer long last year????? "Timholt" says to wait till it gets hot out?...please.... These trucks were spotted down south all last summer, im not so sure heats gonna be a problem for them.
__________________
Adam - - Collision/Refinishing Tech
2002 7.3 POWERSTROKE
100,000 miles
Straight Pipe, 6637, HPX line, pryo gauge, Foil Delete, WW, 6.0 IC + TC. Superchips Tuner.
F-350 Rear Blocks, Leveling kit
  #19 (permalink)
BowTieHatr BowTieHatr is offline
BowTieHatr has a very good reputation on FTE. BowTieHatr has a very good reputation on FTE. BowTieHatr has a very good reputation on FTE.
ignorance is bliss arod.
  #20 (permalink)
Old 03-27-2007, 03:16 PM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a good reputation on FTE. biz4two has a good reputation on FTE.
Thumbs up
Quote:
Do you have a copy of FourWheeler May 2007 edition, page 16?
If not, then you might go out and buy one...so you can see for yourself. According to the mag... the 4.4L is a V6.
biz
__________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
1976 F150 LWB Custom 4x4 390FE NP435 3.50s
  #21 (permalink)
Old 03-27-2007, 03:22 PM
biz4two's Avatar
Arrow
Quote:
I agree...the heat shouldn't be a big deal as it was with the 6.0L PSD. Afterall, the 6.4L PSD has WAY more cooling capacity...with a larger radiator and a water pump that doubles the 6.0L flow rate.
IMO...it is unfortunate that the 6.4L is going to be a short production run. But if FORD and NAV cannot play well together, then it's best that FORD take the soon to be new 6.7L and design it in house.
biz
__________________
  #22 (permalink)
Old 03-27-2007, 04:58 PM
THE KING THE KING is offline
THE KING is starting off with a positive reputation.
ITS A NEW ENGINE! Let them figure it out. If you have to point fingers look at the 5.4 when they first came out! My dad bought one and it didnt even have 1000 miles on it and it blew up. Ford was on that problem fast and put in new motor that was better. All i gotta say is if ford screws this up, i dont know what will happen. They need this motor to take off and do good. And with the thing about ford making an in house motor. If i remember right ford came up with the fuel injector system on the 6.0? That didnt work out to well. I might be wrong but i thought i read that once.
  #23 (permalink)
Old 03-27-2007, 04:59 PM
origcharger origcharger is offline
origcharger is gaining momentum as a positive member of FTE. origcharger is gaining momentum as a positive member of FTE.
One guy says they didn't test them hot, one guy says they didn't test them cold.
__________________
2004 E-450 6.0 137,500 miles
7,500 mile, 15 quart oil changes, 5W-40 Rotella.
UOAs consist of checking for metal on drain plug magnet. All stock, no mods. Dyed fuel with no additives. Never been reflashed.
Total parts replaced;
one EGR valve.
  #24 (permalink)
Old 03-27-2007, 05:01 PM
LOL Did they test them at all? LOL O geez. I thought i saw a couple durring the winter time so i know they tested them cold, and they tested them alot. I saw these trucks at least once a day on the highway and around down.
  #25 (permalink)
Old 03-27-2007, 06:32 PM
biz
I do not need the magazine, as I do believe that is what it says. Maybe it was a misprint. The 4.4L will be based off the 3.6L TDV8. The 3.6L TDV8 (recently released in Europe) was devloped from the old 2.7L TDV6 (no longer in production).
__________________
  #26 (permalink)
Old 03-27-2007, 07:20 PM
fonefiddy fonefiddy is offline
fonefiddy is gaining momentum as a positive member of FTE.
I'm sure the 6.4 will be fine. There will be a few bugs, as ANY new engine platform has.
As far as an in house diesel. I can't see why Ford can't jsut bring one over from GB. Heck, they built the new plant, and supposedly it's capable of 700,000 units a year.
__________________
93 F One Fiddy- 5.0/AOD/3.55 230K OEM
93 F Two Fiddy Scab- 7.3/ZF5/3.55/Sidewinder II,94 Turbo pump,G Inj's, Velvet Ride, Ride Rite Rear, Turbo Bumper, Alcoa's
85 F Two Fiddy-6.9/C6/3.54/ Holley Red, Racor, Soup Bowl,AutoJet 3",Ride Rite Rear
http://www.ford-trucks.com/user_gall...149391.520.390
  #27 (permalink)
Old 03-27-2007, 07:39 PM
To solve all the problems. Bring out a Redesigned 7.3! Improve on some of the very few problems, and make it so it fits the emissions standards. The 7.3L is a Perfect Foundation and i know that many people would agree. Ford made the biggest mistake by changing that motor!
  #28 (permalink)
Old 03-27-2007, 08:16 PM
a-rod's Avatar
I agree, a redesigned 7.3 to meet emission standards, Even if its completly reworked with twin turbos, It would still sell like crazy being a 7.3.
__________________
100,000 miles
  #29 (permalink)
Old 03-27-2007, 08:23 PM
Yea the 7.3 Has a Great name! Good Reputation.
  #30 (permalink)
Old 03-27-2007, 08:24 PM
jvoigt's Avatar
jvoigt jvoigt is offline
jvoigt is starting off with a positive reputation.
It would be nice if they could just stuff a 7.3L in a new SD.......I am sorry but I still think there would be problems.....The Eng block would be the same but thats about it, new Piezo injectors, glow plugs, cooling system, and possible twin turbos plus not to mention its gonna have a DPF and it could still be a flame thrower if they dont do it right. About the only advantage is the Displacement. I love my 7.3L but it is decades away from becomeing the new Diesel engine of the future.
__________________
'02 Dark shadow Grey F250 SC 7.3L Lariat 4X4 (Mods:Volant Intake, MBRP 4", 2.5" Leveling Kit, F-350 Blocks, Dick Cepek DC-1's, 35"x12.5"R17 Toyo MT's)
Tags
2010 , 250 , 4x4 , 67 , accessories , aftermarket , boss , dc1 , diesel , eng , f250 , foerd , ford , frod , rord , truck , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
